DECODE SIZE ERROR? Korg MS2000
man-009
Real name: Timothy
Gear: MS2000
JP8000
blofeld
evolver
virus
AN1x
TG33
The Curse Of Lilith Ratchet on TUBI
Band: view so cruel
Post by man-009 » Wed May 18, 2011 11:32 pm
My Korg MS2000 says this when powered on.... DECODE SIZE ERROR. does it need an OS? and is this easy to put in?... HELP! bought it this way hoping it can be fixed. or..is it trashed now because of this? i was told the former owner tried to update it and it failed in the process. he had tried a few times. no go.
gmeredith
Band: Warning Will Robinson
Re: DECODE SIZE ERROR? Korg MS2000
Post by gmeredith » Thu May 19, 2011 12:50 am
Are you running it on XP? It can be fixed - apparently its a windows XP problem, not the Korg:
http://audiocookbook.org/audio_news/kor ... re-update/
Also:
http://www.korgforums.com/forum/phpBB2/ ... 4a5d660334
and http://www.korgforums.com/forum/phpBB2/ ... hp?t=41588
Make sure you download the firmware update for the Korg;
http://daz.korgforums.com/ms2kos107_2k9.zip
You can use MIDIOx to upload it to the MS:
http://www.midiox.com/zip/midioxse.exe
Hope that helps.
Cheers, graham
man-009
Real name: Timothy
Gear: MS2000
JP8000
blofeld
evolver
virus
AN1x
TG33
Band: view so cruel
Post by man-009 » Thu May 19, 2011 12:57 am
will give it a try! thanks!!!!!!!!!!
man-009
Real name: Timothy
Gear: MS2000
JP8000
blofeld
evolver
virus
AN1x
TG33
Band: view so cruel
Post by man-009 » Thu May 19, 2011 12:58 am
the guy i bought it from is in the link on the forum. he has xp and 7. he gave up. i bought it for $250. hope i can fix this??? hope its not a $250 piece of art now???...lol
gmeredith
Post by gmeredith » Thu May 19, 2011 1:09 am
I'm sure it will be oK - like the posts seem to say, it's an XP registry problem, not the MS.
man-009
Real name: Timothy
Gear: MS2000
JP8000
blofeld
evolver
virus
AN1x
TG33
Band: view so cruel
Post by man-009 » Thu May 19, 2011 1:18 am
so maybe i finaly got a good deal on a synth then!!!!..$250 for a MS2000! besides the OS problem the seller says it's in near mint conditon but missing two knobs. partsisparts can fix that issue for me. they deal with all korg parts! i will try it when i recieve the synth. thanks sooo much!
man-009
Real name: Timothy
Gear: MS2000
JP8000
blofeld
evolver
virus
AN1x
TG33
Band: view so cruel
Post by man-009 » Thu May 19, 2011 1:19 am
DECODE SIZE ERROR
just wondering what this means???
gmeredith
Post by gmeredith » Thu May 19, 2011 1:43 am
I think its referring to the MS not receiving the correct expected data file chunk size over MIDI for the OS firmware file...I have had similar error message like this before when upgrading firmware in other equipment - "checksum error" which probably means the same thing as the MS error. In my case, it occurred when I was using a different program other than MIDIOx to upload it. Changing to MIDIOx fixed the issue...apparently some uploading programs are better than others at passing on correct data packet sizes... MIDIOX is by far the most reliable and trustworthy I have tried.
man-009
Real name: Timothy
Gear: MS2000
JP8000
blofeld
evolver
virus
AN1x
TG33
Band: view so cruel
Post by man-009 » Thu May 19, 2011 2:10 am
i have never done any updating via midi before so this will be a first for me. thanks for the cool info! wil need to find info on how to start all this...:)
gmeredith
Post by gmeredith » Thu May 19, 2011 3:50 am
No problems..just ask :)
man-009
Real name: Timothy
Gear: MS2000
JP8000
blofeld
evolver
virus
AN1x
TG33
Band: view so cruel
Post by man-009 » Fri May 20, 2011 1:36 am
thanks sooo much!. a friend who has done this before on synths is helping me next week. will let you know the results! he will use a mac. this should be ok right?
gmeredith
Post by gmeredith » Fri May 20, 2011 2:12 am
Let's hope so, should be OK with Mac
man-009
Real name: Timothy
Gear: MS2000
JP8000
blofeld
evolver
virus
AN1x
TG33
Band: view so cruel
Post by man-009 » Fri May 20, 2011 2:19 am
cool. if it ends up working. i only paid $250...:)
man-009
Real name: Timothy
Gear: MS2000
JP8000
blofeld
evolver
virus
AN1x
TG33
Band: view so cruel
Post by man-009 » Thu May 26, 2011 5:02 am
well, i recieved the synth today! poor packing job. the box was too big and the synth bounced around a bit. all the styrofoam fell off of it but i was lucky! it was all intact! so we put the OS version 7 update in and....nothing! still had the error message. then we found some german bootleg OS online that loaded perfect but had no sounds? but it wipped out the decode error message! then we put in the right KORG OS 7 and it all worked perfect! it lives!!!! not sure what the seller did wrong? so now i have a mint MS2000! thanks to all here at VSE for your help!
gmeredith
Post by gmeredith » Thu May 26, 2011 6:07 am
Hey that's great news - i knew it would work out ok - since it's software, not hardware, there should be no reason why it couldn't get going again. I had a similar experience updating my Roland MS-1 sampler - the last update which was actually on the Roland site was corrupt and gave those sorts of errors - I thought I'd cooked it. Looked around on forums and found I wasn't the only one so I emailed Roland about it and they sent me the previous OS before that one (which WASN'T on their site for me to try and recover it) and it worked like a charm!
Cheers, Graham
