How to use Harware Synth Sounds with FL Studio?
Mr.Andy6
Post by Mr.Andy6 » Thu Jun 16, 2011 1:44 pm
Hi, I have never used a MIDI-sequencer before but now I want to start that and have some problems.
I have downloaded FL Studio 9 Producer Demo and connected my Synth via MIDI to the computer.
What do I need to do now that FL Studio plays the recieved MIDI data with the sound of the synth? Is that possible overall if the synth is only connected via MIDI to the pc? If I understood right, MIDI transfers only data like Note lenght, pitch etc but no Audio.
Desecrated
Re: How to use Harware Synth Sounds with FL Studio?
Post by Desecrated » Thu Jun 16, 2011 3:11 pm
If you want to record the sound of your synth, you should hock up the line out to the line in on your soundcard.
Midi is only for controlling things like software synths.
Desecrated Productions officially endorses F-1 Guitarpicks:
http://www.f1pick.com/
Mr.Andy6
Post by Mr.Andy6 » Thu Jun 16, 2011 9:11 pm
thanks, I will do that^^
Real name: Unpronounceable
Band: Eridani V
Post by Ashe37 » Fri Jun 17, 2011 3:46 am
MIDI can also be used to *control* hardware synths. Yees, you still need seperate audio.
Post by Stab Frenzy » Fri Jun 17, 2011 10:17 am
Isn't this covered in the manual?
Mr.Andy6
Post by Mr.Andy6 » Fri Jun 17, 2011 12:42 pm
I haven't found it there, but I also haven't read trough it very carefully. Could be that I didn't see it.
silikon
Real name: Ms. Jackson
Band: Year with no summer
Post by silikon » Fri Jun 17, 2011 4:50 pm
I'm certain it's in the manual. You'd hook up your hardware synth's midi to the midi on your soundcard/computer (ensuring that a minimum your midi out from the computer to the midi in on the synth).
You would then take the audio outs of the hardware synth, and connect them to the audio ins on your soundcard.
Once that's done you would need to map any midi tracks to the midi connection of your hardware synth, and map the audio ins to one or more tracks on the mixer.
It may sound painful at first, but a look through the manual should give you the proper direction.
Desecrated wrote:Midi is only for controlling things like software synths.
And if that were true, then no hardware synth's would have midi in/out/through ports. A cursory look at most any hardware synth built in the last couple decades will show your comment to be way off.
echo 1 > /dev/awesome
Post by Stab Frenzy » Sat Jun 18, 2011 10:43 am
Mr.Andy6 wrote:I haven't found it there, but I also haven't read trough it very carefully.
Come back when you have.
Jabberwalky
Band: Variar
Post by Jabberwalky » Sun Jun 19, 2011 9:53 pm
Insert a "Midi Out" instrument channel. Set it to the proper channel of the hardware synth. Give it some piano roll notes.
Mr.Andy6
Post by Mr.Andy6 » Mon Jun 20, 2011 9:45 am
I have no soundcard here but when I have one I will do that. In the mean time i will use softsynths with FL Studio.
Roby31
Real name: Roberto
Gear: Waldorf Micro Q (Yellow)
Access Virus TI 2 Desktop
Casio VL-1
Post by Roby31 » Mon Jun 20, 2011 2:15 pm
How do you listen to stuff without a soundcard? To boot, even the integrated chip's crappy line in can be useful to learn how it's done (so you can set up a .flp file to use as default, init "preset" for your hardware)
Sorry for my unintentional killing of the English language. I'm Italian, you know :) - "What would Jexus do?" - Stew-diah
Mr.Andy6
Post by Mr.Andy6 » Mon Jun 20, 2011 9:10 pm
I have read that the computer soundcards are difficult to connect and quiet crappy quality...isn't it wiser to use external audio interfaces?
Band: Eridani V
Post by Ashe37 » Fri Jun 24, 2011 5:45 am
Crappy quality? A gamer sound card yes- a real sound card no. Putting a single card into a PC and then attaching some cables to it...
