ms 20 questions
construct09
- Real name: b
ms 20 questions
Hi, I don,t fire up the ms20 as much as I probably should, I have noticed that when I switch it on there is no sound when I hit a key until it 'warms up' for say..30 seconds, is that usual? I,m also curious as to whether the attack time(adsr) may have been modded, when set at max a note dosent sound for approximately 1min 30sec?!
- pflosi
Re: ms 20 questions
My MS20 does not need time to warm up. Everything's there from start up, it's also in tune right from the beginning. So that might be some problem with your psu or sth. Don't know about the exact attack time, but it is quite long at maximum. So I guess there's no problem there.
- Hybrid88
- Gear: V-Synth, and other stuff...
Re: ms 20 questions
Yeah, that doesn't sound right - maybe a something to do with the VCA isn't making connection until it warms up and the expansion makes connection again - could also be a crack in the PCB trace or a dry joint perhaps.
By the way I'm curious, where is GTown?
clubbedtodeath
- Expert Member
Re: ms 20 questions
My MS20 doesn't do this either - it's in tune and ready to use as soon as it's on.
Synthacon
- Gear: Hard and Soft Synths
Re: ms 20 questions
My MS10 was in tune straight away, my MS20 was always almost there but certainly after a couple of minutes it was spot on.
You always want just one more Synth!
construct09
- Real name: b
Re: ms 20 questions
hmm.. thats dissapointing, this is one of those mint looking 20s I got from japan with the orig case and overlay sheet etc, could it just be the psu needs a recap? ....Gtown? Oh, thats GEELONG in VICTORIA, AUSTRALIA.
- Stab Frenzy
Re: ms 20 questions
Nobody calls it Gtown do they? We always called it The Schlong.
- pflosi
Re: ms 20 questions
don't capitulate, it should not be too hard to fix. MS20s are definitely worth to be kept alive.construct09 wrote:hmm.. thats dissapointing...
(Btw, is it an older or newer version MS20? I have a newer one, don't know whether that changes something on this issue or not...)
Re: ms 20 questions
Just a bad contact somewhere....Push the connectors in first.
First or second versions are the same except for the filter....And they don't sound that dissimilar (I have both)
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
construct09
- Real name: b
Re: ms 20 questions
yeah, its the later version....iv,e never been inside , do you just remove an end'cheek'?
the schlong huh? G-hole is more apt....where the f#cks monster Isle....Tassie?
