Roland Juno 60 resets saved patch to on-board setting?-HELP!
akruziki
Post by akruziki » Sun Nov 13, 2011 11:08 pm
I have a Roland Juno 60, recently acquired, and have been using it to build a new bank of saved patches, to be used in a live performance setting. Occasionally, I will be playing on a saved patch and my J-60 will automatically reset itself to the on-board keyboard settings (everything from the envelope, LFO, VCF, chorus, etc.). This is extremely problematic in live-performance situations, when I need to rely on the saved patch NOT switching itself off.
Could this be from the PSU? Does anyone have any suggestions or ideas? Thank you endlessly!!
-AKru :mrgreen:
cornutt
Gear:6th
Re: Roland Juno 60 resets saved patch to on-board setting?-H
Post by cornutt » Tue Nov 15, 2011 3:27 am
Do you get the "edited" indication (decimal points appearing in the patch number) when this happens? It sounds like the "manual" button has gotten flaky.
synthparts
Post by synthparts » Tue Nov 15, 2011 2:23 pm
Actually this was a problem with the power supply wiring to the panel board. Roland released a service bulletin to fix it by rewiring the board with new +5 and ground wires. I have done it on a couple of mine and it fixed the prob.
akruziki
Post by akruziki » Mon Nov 21, 2011 12:00 am
The decimal points only appear when I go to change the patch. When the patch resets itself, the 2 digits on the patch Memory go to "--", reseting the Juno-60 to the on-board settings.
Do you have any idea how to find the bulletin from Roland? I looked but was unable to find... Much thanks!!
ssteve940
Post by ssteve940 » Sat Oct 10, 2015 1:11 am
I'm currently going thru the same exact issue, does anyone have any updates on this?
Thanks!
Steve
CoolSail
Re: Roland Juno 60 resets saved patch to on-board setting?-HELP!
Post by CoolSail » Sun Mar 20, 2022 3:00 pm
Hello dear J60 lovers,
I do have the same issue Patch reseting...I am pretty upset with that...
Please Synthparts, could you give me a draft, or whatever who could help me on fixing this issue. I am pretty novice, but I think I can do basic soldering...
Thanks a lot for any help on this !
CoolSail
Post by CoolSail » Mon Mar 21, 2022 12:40 pm
Hello, I do have the same issue. Please could you tell me how to do it. I assume that I have to soldier 2 wires from Carboard B and to electricity board...Could you give a draft please it will help a lot ! Best regards, Cristo
CoolSail
Post by CoolSail » Fri Mar 25, 2022 2:08 pm
Issue solved for me : The "2 digits display"s little Card wasn't strongly screwed on the panel board B.
4 screws, problem fixed.
