Prophet 5 Noise Circuit
tomorrowstops
I hadn't really played around too much with the noise function of my P5 (rev 3.2) until now.
When utilizing the white noise circuit by itself, I'm getting a pulsing signal with it, almost like if the LFO section was leaking voltage. However, no matter what knob I twist, I cannot manipulate the rate of this pulse, nor make it go away.
Is this a problem, or the nature of the beast? My Voyager OS has a nice, pulse free noise circuit.
- snod_donkey
- Gear: Moog Minimoog - SCI Pro-One - Roland Sh-101 - Yamaha XS6 - Oberheim OB-Xa - Roland TD8 - Evans super Echo Tape Loop - Memeory Man Deluxe
Re: Prophet 5 Noise Circuit
Well i have just tried my 3.2 with only noise and no modulation and it does have a sort of constant lfo with it... sort of a tick in the sound a bit faster than every second
Never noticed that before so thanks!! Gonna bug me now!
tomorrowstops
damn, sorry mang!
at least these two are the same....
anyone else?
anyone else?
- rhino
- Real name: bill
- Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Poking my $0.02 in where I have no business. IIRC, many vintage synths generated noise using a shift register - randon 1's and 0's are clocked in a loop, with feedback to keep things stirred up. But, there IS a periodic repeat of sorts that will sound like a pulse.
- Confucius
- Confucius
- snod_donkey
Yep i was thinking its sounding rather digital - most likely based around a MM5837 ic which goes in a loop so that would explain it.
adhmzaiusz
I also read this and indeed it is true with the P5, you are hearing the looprhino wrote:Poking my $0.02 in where I have no business. IIRC, many vintage synths generated noise using a shift register - randon 1's and 0's are clocked in a loop, with feedback to keep things stirred up. But, there IS a periodic repeat of sorts that will sound like a pulse.
- snod_donkey
Just checked the circuit and yes there is a 5387 in the noise circuit... that being the case i would say your sound is ok
tomorrowstops
Sweet, very helpful post indeed, EdGs!
A little beyond my capabilities, but once my techie pal gets my Linndrum all ship shape, I'll see what he can do with this circuit!
- snod_donkey
tomorrowstops wrote:Sweet, very helpful post indeed, EdGs!
Nice.. have a p5 and also got a Linndrum last week. Just rebuilt and serviced it too
EdGs
- Gear: Prophet 5 and Emulator 1, both are works in progress
Epiphone LesPaul Ace Frehley
Hondo Formula One Vee
Fender Gemini IV - Location: Florida
You're welcome! It seems to be a neat mod to do. However, the noise chips in my P5 are not marked MM5837, instead 8119DB. I'm not quite sure what the deal is there. Possibly an upgraded chip or different manufacturer's # for an eqivalent part? Mine's a rev. 3.3 s/n 4992.
- snod_donkey
Noise ic should be U366 and in the service manual is shown as a 5837 but this was a rev 2 i was looking at so it may well have changed later
Just found a later rev manual and it says u427 5837
EdGs
Yeah, the rev.3 tech manual says 5837. But that pic is U427 in my machine. The other noise chip on board 3 (U375)is the same. I could not locate a datasheet for this one either. Definately strange.
tomorrowstops
snod_donkey wrote:tomorrowstops wrote:Sweet, very helpful post indeed, EdGs!
shooooot - meaning you are now playing with it? I bought mine non-functioning over a month ago. Turn it on, no lights, no sound (except for the humming xformer). Batteries exploded all over the power supply board. Cleaned it up, replaced the batteries, recapped the power supply, still nothin'. Currently reading about replacing the xformer....
*sigh*
- bhrama
- Gear: Sub 37, TR8, Streichfett, Tempest, P6
- Band: Grit Lapse, Mangkind
I have a rev 3.0 and mine says the same thing...EdGs wrote:Yeah, the rev.3 tech manual says 5837. But that pic is U427 in my machine. The other noise chip on board 3 (U375)is the same. I could not locate a datasheet for this one either. Definately strange.
Also did the whole sound check and its quite similar, if not identical to what you all describe as "digital" sounding, in that it seems to have a a pattern.
