My juno 6 seems to always remain with the hold light on and hold engaged. Regardless of weather the button is pressed or not. Might this just be a dirty contact? Or something i could easily clean or repair? Im a bit on the broke end of things and im trying to avoid taking it to the Doc just yet. Any ideas?
thanks,
Nick
Juno 6 stiky hold button
Horace
- Gear: Juno 6, MG-1, 707, ES-1, KP3, x0xb0x, 2 turntables, a microphone
Re: Juno 6 stiky hold button
It could very well be an easy fix. I would pop the hood and clean the contact/switch assembly. Could also be a short on the board. Be careful not to flex the board too much when you take it out!
- synthparts
It could also be that the hold pedal jack is shorted. I have both the switches and jacks if you need them.
