So I plugged my Juno 106 in and nothing works....at all. It's a Japanese model and I live in America, but I thought I would try and plug it in real quick and just try it out to see if it works. Is this why it's not working or do I just have a shitty device? I sure hope it's the former...
(PS, all I hear is static noise when I turn it on)
JUNO 106 NOT WORKING! HELP!
- Alex E
- Gear: always in flux
Re: JUNO 106 NOT WORKING! HELP!
I've heard 100v synths -can- work in the states for a little bit, but this one might not be working here.
You probably didn't hurt it the first time, but don't try again until you have the right power converter.
soundcloud.com/vectron
reckoner421
Do you think this is probably the issue? I did open the system up for cleaning (the keys were disgusting), but didn't touch any of the motherboards or switches...I simply put all the screws back the way I took them out so I think its highly unlikely that I did anything to it. I'm just praying that it's not a broken unit. Where are some good cheap voltage converters that I could buy at a store tomorrow to test this out? Do they even exist in stores?
- Alex E
Try radio shack. First place I'd go at least.
And nah, there's no danger in opening them for a cleaning.
Just don't mess with trim pots, haha.
- fh991586
- Real name: Francis
- Gear: Korg Kaossilator, MicroKorg,
Midines - Location: French Canada
If you can tell us the settings you're trying to play, it may help us check if there is any good sound coming from a working 106 with the same settings...
Available for sale:
- fh991586
But first, please refrain yourself from doing multiple postings: I just noticed you already asked for advice for the same unit in another post.
Available for sale:
