Playing around with bass sounds on the P08. I finally got the super fast amp envelope clicking under control by dialing in a sweet spot on the attack dial. But now I've discovered a new clicking/squeaking noise:
I put a 7 band eq on it and discovered its in the 3k range. I was able to attenuate it with a moderately shaped q, without affecting my original sound. But what the heck is it originating from? I'm running in single voice unison mode, outputs set to mono, zero modulation/lfos, 2-pole filter. In testing, I'm noticing it now on other DSI presets, basically anything with a lower cutoff frequency.
I'm assuming this is just inherent with these machines. Anyone want to chime in here?
Prophet 08 Mystery Clicking/Squeaking
tomorrowstops
slingdinger
Re: Prophet 08 Mystery Clicking/Squeaking
Did you ever get this figured out? Mine does the same thing. The sound is so distracting that certain patches are just useless.
