Pro One pots
nuromantix
Pro One pots
Post by nuromantix » Tue May 01, 2012 8:10 pm
Can anyone suggest a replacement for the 100K pots in a Pro One?
Vintageplanet have NOS but they want 26.50 Euros for one, that means I'm looking at about 600 euros to pleace the pots!
A link to a suitable part at Mouser or Farnell etc would be really helpful.
I'm not sure about the physical size and power rating etc.
Don T
Real name:Don
Gear:Roland SH-09, Korg Polysix, Moog Rogue, Realistic MG-1, Paia Fatman, Korg Monotron, and of course, my main instrument: Trumpet!
Re: Pro One pots
Post by Don T » Wed May 02, 2012 12:45 am
Don Taylor
synthparts
Re: Pro One pots
Post by synthparts » Wed May 02, 2012 1:57 am
I have them for $12 each.
EdGs
Gear:Prophet 5 and Emulator 1, both are works in progress
Epiphone LesPaul Ace Frehley
Hondo Formula One Vee
Fender Gemini IV
Re: Pro One pots
Post by EdGs » Wed May 02, 2012 2:25 am
+1 on what DonT said.
I had to replace all the pots in my Prophet 5, and I found some at digikey that were the same size, but I had to do ALOT of modding to get them to work. All the originals were frozen or broken due to long storage, neglect, and anvil case foam deterioration/moisture.
WCS lists pots for the Pro One, but says email for options. They will probably be pricey.
Also, check with Doug at synthparts.com. He may be of help.
I have no idea if the pots of the P5 are similar to those in the Pro One, but the digikey part # for 100k is 450D104-6-ND (theses pots are solder lug type, not PCB mount). My machine was a basket case and then some. But the replacements worked out great and only cost $75 and some time (WCS would have been about $400 for the pots alone).
I can post the writeup here if anyone is interested.
EdGs
Fender Gemini IV
Re: Pro One pots
Post by EdGs » Wed May 02, 2012 2:37 am
Synthparts was a bit quicker than me with the post. He has alot of good stuff there.
nuromantix
Re: Pro One pots
Post by nuromantix » Wed May 02, 2012 1:39 pm
Thanks folks.
I'll try some cleaning first then I'll go to synthparts!
Some of the pots are crackly (osc & noise levels, cutoff) and the envelope ones behave erratically as if there are some "dead spots" in the pots.
