Oberheim SEM Patchpanel oscillator noise when idle
volumetrik
hey
I noticed that when my SEM is idle you can hear this very faint oscillator noise and if you turn up the mixer or monitors you can hear it more, is this ok?
cheers
cheers
Re: Oberheim SEM Patchpanel oscillator noise when idle
That happened with my moog mg-1. I thought it seemed normal. Is it loud enough to cause annoyance?
volumetrik
I guess not...did you end up servicing your mg-1?
- meatballfulton
- Gear: Logic Pro X
Welcome to the wacky world of analog circuitry
If you need it dead quiet, use a noise gate.
No, I think that is just the way they are like meatballfulton said, it really shouldn't matter as long as its not so loud that you can hear it through your mix. If you have to turn your pa or system up to hear it, its probably not a problem. If you can hear it very clearly with normal playing volumes, it may be a problem.
My guess is that its fine.
- synthparts
Do you have both VCO1 and VCO2 saw/pulse mix pots totally off (in center position)?
volumetrik
when they are in center position, there is no noise but as you turn them the noise appears and you can hear it more as you turn it to the maxsynthparts wrote:Do you have both VCO1 and VCO2 saw/pulse mix pots totally off (in center position)?
btw thanks for the help every1
- synthparts
OK so if by "noise" you mean the sound of the VCOs then it's working fine if you have the VCA On switch set to On. That makes the SEM constantly output sound. Turn off that switch and you should only hear sound when there is an incoming gate signal...volumetrik wrote:when they are in center position, there is no noise but as you turn them the noise appears and you can hear it more as you turn it to the maxsynthparts wrote:Do you have both VCO1 and VCO2 saw/pulse mix pots totally off (in center position)?
volumetrik
I mean when I'm not playing the unit there is noise when the VCOs are switched on..synthparts wrote:OK so if by "noise" you mean the sound of the VCOs then it's working fine.volumetrik wrote:when they are in center position, there is no noise but as you turn them the noise appears and you can hear it more as you turn it to the maxsynthparts wrote:Do you have both VCO1 and VCO2 saw/pulse mix pots totally off (in center position)?
volumetrik
yes VCA is switched off also..
