MS2000 arpeggio out
MS2000 arpeggio out
Trying to get it to output the arpeggio over midi....No luck so far...
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
- madmarkmagee
- Gear: King Korg
ESQ-1
Reface DX
Microbrute
Shruthi-1
Pittsburgh System-1
Juno 106 (needs work) - Location: Sydney
Re: MS2000 arpeggio out
Can it do that? If it can then do you have the right midi setting selected? I know on my R3 you have to choose a specific midi setting then turn the Apeggiator on and it will work. Consult the manual.
The manual is quite vague on this...Could be the same as the micro..?
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
- madmarkmagee
- Gear: King Korg
ESQ-1
Reface DX
Microbrute
Shruthi-1
Pittsburgh System-1
Yea, took a look at my R3 manual and the MS 2000 manual. You have to go in to the global settings (discussed on page 53 of the MS 2000 manual PDF I'm looking at) and change the "position (Page 1, C)", to "post KBD". Then It should be as simple as plugging in the midi cables and playing the notes on the MS 2000 and they should arpegiate the slave keyboard.
- Zardoz
- Real name: Not Zardoz
- Gear: Zardoz is pleased.
- Band: Pecora Pecora
Yes that's it ( post KBD ), I did that sometime ago on mine and it does the trick.madmarkmagee wrote:Yea, took a look at my R3 manual and the MS 2000 manual. You have to go in to the global settings (discussed on page 53 of the MS 2000 manual PDF I'm looking at) and change the "position (Page 1, C)", to "post KBD". Then It should be as simple as plugging in the midi cables and playing the notes on the MS 2000 and they should arpegiate the slave keyboard.
My dear friends....IT WORKS
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
