Very simply,
there doesnt appear to be a way to turn off a latched key, without switching the whole arp section off and back on. Hoping someone can correct me on this, or that there is a specific mode that needs to be selected/etc...
Seems extremely weird, given that most synths keys just act as toggles for latch, ie one press engages, the next disengages...
MS2000 latch off.... :/
Re: MS2000 latch off.... :/
You should be able to turn the latch on and off while the Arp is running, without having to press any other buttons.
- Stab Frenzy
- Gear:Eurorack, RYTM, Ultranova, many FX
Yeah you just press the latch button again don't you?
- divineaudio
- Gear:far too much.
- Band:metria
yep, you'll need to turn off the latch button on the arp section. the keys will only trigger/retrigger notes.
