Any idea how you plug a JV 1080 inot a DAW using a controller keyboard?
Gear is:
DAW: Sonar X2 Producer
Controller: Akai MPK 49
Synth: JV 1080
JV 1080
- Alex E
- Gear: always in flux
Re: JV 1080
Connect the midi out of your MPK into the midi in of your module.
From there I'm pretty sure you can configure your MPK as a midi interface for DAW use. How? Not sure. Check the manual.
soundcloud.com/vectron
