JUNO 106 LED failure
n00bzill4
Post by n00bzill4 » Tue Dec 11, 2012 12:56 am
Hey there,
The LEDs for the sawtooth or square waveform select have both stopped working at the same time, the switches still function as they should though. I thought it was strange that both should drop out simultaneously unless if one went it would mean the other wouldn't work either? Or is there another obvious suspect?
Cheers
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: JUNO 106 LED failure
Post by rhino » Tue Dec 11, 2012 3:43 am
Welcome to the board!
If ONLY those two LEDs do not light:
1) both leds failed
2) bad copper trace near them
If those leds AND CHORUS I and II, 4', 8',and 16' are dark:
1) IC 15
2) bad trace
Try jumpering the bad leds - one at a time - with new ones.
- Confucius
n00bzill4
Post by n00bzill4 » Tue Dec 11, 2012 12:07 pm
Thanks very much Rhino for the welcome and advice,
I've cracked open the case and I'm pretty sure I've found the fault, the D55 track appears to have corroded through between the chorus and sawtooth LED. Please bear with me as I've only got minimal experience with this type of thing..... I have conductive paint but I'm not sure this would work as the track is insulated? Worth giving the track a scrape and giving it a try? If not I'm guessing the fix would be to solder a wire fromm D55 on the chorus LED to D55 sawtooth LED?
n00bzill4
Post by n00bzill4 » Tue Dec 11, 2012 12:14 pm
n00bzill4
Post by n00bzill4 » Tue Dec 11, 2012 12:58 pm
Well I decided to throw caution to the wind, scraped back the insulating layer with a blade and there was definitely a break.
I had some conductive paint I'd used for a motherboard voltage mod years ago, I figured at worst I could just scrape it back of again.
Voila.
Maybe this might be of use to somebody that needs to do a small repair but isn't confident with a soldering iron.
Cheers
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Tue Dec 11, 2012 5:02 pm
Nothing succeeds like success!
Good work!
- Confucius
cornutt
Gear: 6th
Post by cornutt » Thu Dec 13, 2012 2:47 pm
Interesting. Never seen that happen on a 106. It must've had something spilled on the panel at some point.
