Here's what I've found so far:
Errors:
- Voices: Only voice channels 2 and 3 work - the rest are either silent or make rumbling sounds.
- Saving patches: Saving patches to user memory (Patch banks C and D) doesn't work. Patches stored in factory preset banks (A and B) seem to be OK.
- LED's: "8", "16", "D" and "Tape Memory" indicators are constantly blinking ("Tape Memory" at a higher rate than the rest). These LED's are on the same row in the LED matrix, sharing the D7-signal. I've chased the activity for the D7-signal on IC44 pin32, which on my 10MHz scope doesn't seem different from the D0-D6 signals.
- Switches: Nothing happens when the "8", "16", "D" and "Tape Memory" switches are pressed. These switches are on the same row in the Switch Matrix and share the D7 line with the above mentioned LED's.
- Crashing: The entire synth crashes from time to time. I've had it on for hours without any crashes, and then at other times all it takes for the synth to crash is starting the internal sequencer or pressing a few keys simulteneously.
- Power supply: All supply voltages are OK, and present as needed on each individual boards.
- Battery: OK @appr. 3V.
- Internal sequencer: Sequencer plays, records and saves. The recorded sequence is retained in memory, even after having the synth turned off.
