ok, i've read the manual but still can't figure out how to configure the Modwheel and Aftertouch such that they increase/introduce the LFO amount.
just trying to get some simple vibrato from these sources
i know how to get vibrato from the LFO but i want to introduce it with the aforementioned sources.
it may be that i'm still not grasping the interface.
here's my dance.......
- go to LFO 3, adjust rate
- go to MOD, then go to ASSIGN 3
-press the left "parameter" button to choose my desired Source........"Modwheel" (or "ChanPres" for aftertouch)
-press the right "parameter" button to choose my desired Destination......."Lfo3OscAmt"
- get frustrated because there's no vibrato from activation of source
please clue me in
thanks!
Access Virus C...........Modwheel, Aftertouch MODULATION
- chimney chop
- Band: boxc, cigarettes after sex
Last edited by chimney chop on Fri Jan 11, 2013 11:47 pm, edited 9 times in total.
- chimney chop
Re: Access Virus C...........Modwheel, Aftertouch MODULATION
also, no matter where i set the Aftertouch sensitivity (oddly enough "64" is the most sensitive setting) it still takes A LOT of pressure to initiate it.
so much so that i feel a key might break if i press any harder (it's an Indigo 2 so i'm playing it from its own keyboard)
the thing sounds great and would be a home run if i could just figure these things out.
- chimney chop
aHA!
realized that Modwheel wasn't set to Control 1 in the System Menu.
works perfectly now
works perfectly now
