Hi!
Today I found my dads old MKS-30, and decided to try it out.
The sounds were great, the midi worked, but the synth skipped variated notes. I saw no sence in the "skipping", it was no pattern, and it skipped even though I just played that one note.
Have anyone else got the same problem? What to do?
I know it's a great synth, so I really want to have it up running..!
Roland MKS-30 "skip" notes
- meatballfulton
- Gear: Logic Pro X
Re: Roland MKS-30 "skip" notes
The MKS-30 has the same voice chips used in the Juno 106 which is infamous for losing voices over the years. One or more of these chips has gone bad.
Synth Spa is an online vendor who can do the repairs for you...$170 with free shipping both ways. They also do full overhauls for $250.
I'm sure Rhino will come along soon to explain other options for DIY repairs.
- rhino
- Real name: bill
- Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Welcome to the board!
Turn the synth off, then on. Play one note at a time in a scale (any). Keep track of the dead notes. If it skips one out of six, you have a dead voice. Since you hear neither oscillator, the fault is likely in the filter. The filter chips are quite robust for the era, so I'd start checking with the de-multiplexer chip and move from there.
If this post confuses you, take it to a tech. If it skips more than two out of six, or is random, then you have deeper troubles. Still quite worth fixing.
- Confucius
- Confucius
- synthparts
No, the MKS-30 has the same 80017A VCF/VCA chips as the Juno-106. Definitely not "robust"...rhino wrote:Welcome to the board!
- rhino
- Real name: bill
- Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
My bad. Misled by this in VSE: "The MKS-30 is a MIDI rack module version of the JX-3P..."
- Confucius
- Confucius
- meatballfulton
- Gear: Logic Pro X
Well, it is the rack version of the JX3P but it uses the Juno voice chips...typical Roland design philosophy
just like how the MKS-80 is somewhere between the Jupiter 8 and Jupiter 6 design-wise.
The GR-700, GR-77B and MKS-7 also use those Juno voice chips.
- Bitexion
- Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
These synths have X amount of voice chips that decide how high your polyphony will be. The internal software cycles through the voices each time you press a new key. So if one of them is broken, it will stop every time you get to that particular voice chip. Doesn't have to be specific notes. Some synths let you disable faulty voices too. I think you could do that on the Prophet-5? Effectively making it a prophet-4.
I think the Juno/Mks chips contain a full single voice. Filter, oscillator, vca.
My Andromeda A6 has its own menu where you can disable faulty voices too.
- synthparts
The 80017A is just the filter and VCA...Bitexion wrote:These synths have X amount of voice chips that decide how high your polyphony will be. The internal software cycles through the voices each time you press a new key. So if one of them is broken, it will stop every time you get to that particular voice chip. Doesn't have to be specific notes. Some synths let you disable faulty voices too. I think you could do that on the Prophet-5? Effectively making it a prophet-4.
Unfortunately you can't disable bad voices on the Rolands...
