I agree with garranimal. I repair synths for a living and I have seen a lot of bad things happen from novices taking on power supply issues. (I don't know what your level of knowledge and skill is.) If your meter is on DC volts, you will get a reading like 6v on all of the transformer windings. I very rarely see failed transformers, though it does happen from time to time. With the multimeter set to DC volts, check the output of the +5V, +15V, -15V. Are any of these correct? Remember that the transformer here has two secondary windings, and two bridge rectifiers. This means that if you aren't seeing anything on any of those outputs, that the chances of BOTH windings, or BOTH regulators being blown are very slim. Based on that knowledge, we can then point to only a couple things, those being the primary winding of the transformer, the wires leaning from the switch and the noise filter, and the switch. I'm not looking at the schematic right now, but I believe there is also a capacitor between the plug terminals. If it were shorted, you would blow a fuse in your breaker. If you are getting only +5, or only +/-15, then you have a problem with your power supply and will need to chase that down. I usually disconnect the power from each board and test, to be sure that one of the rails on one of the other boards isn't shorted. Hope this helps.
-Rob C
http://www.newenglandanalog.com
