JP8000 Pitch Wheel not working after Battery Replacement
DLovas
Real name:David
Gear:Roland JP-8000
Roland JV-1080
Roland D-550
Roland S-760 (3x)
Waldorf Pulse+
u-he Zebra2
Post by DLovas » Wed May 21, 2014 7:30 pm
Hey guys, for a while now my JP8000 has started up with the messages, *Memory Damaged* and *Battery Low,* so I finally got around to changing the battery. Now here's the problem. Everything seems great except for the fact that the pitch wheel / LFO2 will not work. It wasn't working before I attempted to replace the battery, and I thought nothing of it since I read that the wheel not working was simply a symptom of needing to replace the battery. Any thoughts? I've tried changing the bend range to no avail... The system seems to think it should be working. It's not that big a deal since I don't use it at all when recording, but it's still a tad annoying.
Thanks.
DLovas
Real name:David
Gear:Roland JP-8000
Roland JV-1080
Roland D-550
Roland S-760 (3x)
Waldorf Pulse+
u-he Zebra2
Re: JP8000 Pitch Wheel not working after Battery Replacement
Post by DLovas » Wed May 21, 2014 7:42 pm
Hello again, I've clearly posted this prematurely. I've found the solution. I'll place it below so that others may benefit from it.
From Roland Clan Forums
http://forums.rolandclan.com/viewtopic.php?t=27112
Andy T. wrote:O.K,after you replace the battery in the JP,you will need to perform the following steps to get the bender & ribbon controller to work.
1 Before turning the JP on,hold down the SYNC,12db/24dB and TYPE buttons
2 keep holding the buttons downand turn on the JP.It will take awhile but eventually the screen will show 1 midi test.
3,press 3,display will read 3 Bend Mod.
4 Gradually move the bender fully left and gradually back to centre.Now press the LOWER button.
5 Do the same moving to the right,return to centre and press the UPPER button.
6 Do the same again but pushing the lever forwards and back before pressing the KEY MODE button
7 When a * appears on the screen,press UP
8 Press 4 to show 4 Ribbon
9 press down on the far left of the ribbon and at the same time press LOWER
10 Repeat on the right side and press UPPER
11Pressing on the middle, press the KEY MODE button.
12 when the * appears on the display, press UP.
13 Power off the JP.
Next time you turn on, everything will be fine.STart sweeping those sawtooths!
Hope this helps
Andy
P.S don't forget you will also need to do a factory reset for the Patch mode,Performance mode and the RPS patterns.This is explained in the manual,but if you don't have this,post here,and I will run through the procedure.
Thanks.
Goyogoio
Post by Goyogoio » Sun Dec 14, 2014 10:23 am
Many thanks from Spain!, with your explanations my JP-8000 is alive again!
DLovas
Real name:David
Gear:Roland JP-8000
Roland JV-1080
Roland D-550
Roland S-760 (3x)
Waldorf Pulse+
u-he Zebra2
Post by DLovas » Sun Dec 14, 2014 10:30 am
Goyogoio wrote:Many thanks from Spain!, with your explanations my JP-8000 is alive again!
I'm glad that this was able to help!
SynthVintner
Post by SynthVintner » Sat May 21, 2022 3:33 am
:newhere: Oh, I'm a happy sweeping sawtooth today!! I thought my JP-8000 was toast, but no, I wasn't having it. I got some help from a YouTube video to change the battery - success - but oh no, my second favorite feature after Resonance, the pitch bend and ribbon didn't work.
So back to the interwebs, and voila! It's all good again! :keys1:
Thank you so much dear Andy, for your kind and thoughtful sharing.
:P :agree:
