Ok so I'm having a recent problem with my Roland JX8P. I've come to take its longevity for granted and now I have no backup for using it live (I use a lot of backing tracks so I could get through a show without it, but I digress). Anyways, any input would be appreciated. We have a show in ten days, and I would at least like to find out if it's fixable or if I should start ebaying it up.
For pure comparison I'll link to a before and after recording of whats going on with it. The last time I plugged it in was about a week ago at an outdoor festival. It was raining during loading and unloading (playing under a covered area) and I was sure it didn't get wet. It might have, but that doesn't seem like whats going on with it.
Here's before (control):
http://www.mediafire.com/listen/l5xocwn ... ad_ref.mp3
And this is what comes out when it's played now. It takes a noticeably longer time to countdown(bootup) this time. I'm switching patches while playing a chromatic scale. The interface preamp and mixer are turned all the way up just to get this close to 0dB (weak output):
http://www.mediafire.com/listen/xcgifx5 ... _noise.mp3
Also, it's started to boot normally and works for a few seconds after being left off for a while, then goes back to poo mode. Tried everything. Switching outputs, cables, amps, patches, playing through MIDI in...
JX3P synth repair, please help!!!
thetalkingliberties
- synthroom
- Real name: Kirk
- Gear: Fairlight IIx(!), JP-8, D-50, S-50+550, S-760, JX-3P, JD-800, EII, Emax II, Mini, ARP 2600, P-5 Rev.1, Pro-One, Performer, K1m, K5m, few other things.
Re: JX3P synth repair, please help!!!
Have you checked the voltage outputs of the power supply?
