Actually I was looking for the simplest solution while testing signals, not full mute , just a bit of attenuation.
I am using croc clips on pots , so less wires the better.
So to say all 3 wiring methods actually work. Wiring #3 seems to be the best option
Wiring #1 , as Stab kindly pointed out works by limiting the current. Is it bad ? I dont know, it works though.
Wiring #2 , was actually my bootlegged version of this :
and finally wiring # 3 ,as Stab suggested that by connecting the third lug to ground, it will be dividing the voltage and providing a constant impedance.
