Korg Delta help? Please?
Algorithm
Post by Algorithm » Sun Oct 19, 2014 5:12 am
I have a korg delta that I managed to repair half of. When I received the Delta, it just output a pink/white noise sound, on synth and strings. After replacing the 4 tantalum caps and the lm13600's everybody seems to deal with, it got half of it back. Now it works on the synthesizer side, but I got no strings... I replaced 2 caps, IIRC C1 and C2/or C6... Still nothing on the string side. Anybody have any suggestions? When I search for instances that other enthusiasts dealt with pertaining to the strings, seems like nobody else has had to deal with this problem. Thanks in advance.
Is it trash or treasure?
Paul D
Re: Korg Delta help? Please?
Post by Paul D » Sun Apr 18, 2021 11:35 am
Did you fix this problem??
I have a Korg Delta and the Synth section seems to be OK but the String section isn't working all the time.
When I switched on, initially the strings worked then later when I switched on the strings were dead.
Might be a connection problem or a bad solder joint??
