quick soft popping sound in triangular wave in minikorg
Musicwerks
- Real name: Yeo
- Gear: MaxiKorg DV800, MiniKorg 700s, MiniKorg 700, Korg Prophecy, Korg M3
I managed to makw my junkwlyard minikorg 700 work
The triangle wave also had a mild quick envelope popping sound at the beginning of the note. The other wave signals had no problem. Anyone knows how to fix that popping sound? Is it a case dirty keyboards
- Jabberwalky
- Gear: A hybrid of vintage and modern junk
- Band: Variar
Re: quick soft popping sound in triangular wave in minikorg
Cool, glad you got it working! My minikorg also has a slight popping from the Triangle wave, but it's not that bad.
Musicwerks
- Real name: Yeo
HI Jabberwalky,
Yeah, mine is a soft popping on the triangular too...just that I am a difficult perfectionist
kidding...I will try cleaning the keyboard contacts (my gut feel tells me that the popping is due to the contacts)...or worse case scenario I will change the old VCO the new OEM VCO due to arrive from barcerlona.
I will keep you guys posted on the outcome
Musicwerks
- Real name: Yeo
HI Jabberwalky,
Musicwerks
- Real name: Yeo
HI Jabberwalky,
Musicwerks
- Real name: Yeo
HI Jabberwalky,
Musicwerks
- Real name: Yeo
HI Jabberwalky,
Musicwerks
- Real name: Yeo
HI Jabberwalky,
Musicwerks
- Real name: Yeo
HI Jabberwalky,
Musicwerks
- Real name: Yeo
HI Jabberwalky,
Musicwerks
- Real name: Yeo
HI Jabberwalky,
Musicwerks
- Real name: Yeo
HI Jabberwalky,
Musicwerks
- Real name: Yeo
HI Jabberwalky,
Musicwerks
- Real name: Yeo
HI Jabberwalky,
- pflosi
Duodecuple post! A new record
About the popping, could it be happening because the osc is not at a zero-crossing when "randomly" hitting keys? I.e., a design "error"? It's a common problem in modular, the remedy is to sync the osc to the key gate... With saw / square you don't hear it because of the upper harmonics that are present... Just a wild guess.
