Yamaha DX7 buttons not responding???
rehab
Post by rehab » Tue Dec 16, 2014 4:33 pm
Hello,
I've just recently acquired an old Yamaha DX7 (mk1) keyboard and have been having some issues.
When I first powered it on, none of the sounds would play and the screen said that the battery needed replaced. I also noticed that all the buttons seemed to work other than the 4 buttons in the bottom Memory Select row.
I replaced the battery with one that i purchased from syntaur. I clipped the leads from the original dead battery and soldered the new battery onto the clipped leads.
Powered the DX7 on and the battery message was no longer present and the sounds played fine.
Issue I'm still having is that the bottom row of 4 buttons under Memory Select are still not responding. So all i'm able to do is play the sounds that are off the DX7 data ram cartridge (that came with) but I'm unable to get to any other functions.
Any ideas as to why the whole Memory Select row of buttons would not be responding?
Thanks,
Mike
commodorejohn
Real name: John
Re: Yamaha DX7 buttons not responding???
Post by commodorejohn » Tue Dec 16, 2014 7:50 pm
Since it's only four buttons, I doubt it's an issue with the decoder matrix (I can't find a schematic for it in the service manual, but with as many buttons as there are on the DX7, a non-functional row should probably have a lot more buttons out of commission.) So I'd bet that the switches are just worn out. Luckily, they're pretty easy to replace if you have basic soldering/desoldering skills. The service manual lists it with Yamaha's internal part number KA905510; you can get them for $0.72 apiece here, or order functional equivalents for $0.40 apiece here (at that price, as long as you're in there you may as well replace the whole set - with the price breaks it'll run you about $10.)
rehab
Post by rehab » Wed Dec 17, 2014 7:11 am
Thanks for the link to purchase replacements! Will be looking into this since it is so cheap.
So do u think it's just a coincidence that it happens to be those 4 bottom buttons that are all worn out? Just seems weird to me is all.
commodorejohn
Real name: John
Post by commodorejohn » Wed Dec 17, 2014 7:42 am
It does seem a little odd, and if I could find a diagram for the matrix that shows which buttons are aligned on which rows I could say for sure whether it was possibly a bad connection on one of the row selects. But I can't, and as I said, I doubt there's only four buttons to a row (usually it's eight, so's to fit neatly in a byte-width I/O port.)
rehab
Post by rehab » Wed Dec 17, 2014 8:44 am
The bottom right 4 buttons are the only buttons not working. PSW37 PSW38 PSW39 & PSW40
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Post by Bitexion » Wed Dec 17, 2014 1:10 pm
Well, if those 4 buttons were the most used buttons (maybe previous owner only used 4 presets), then it's quite natural for them to break first. Imagine the amount of presses they have endured since 1984.
synthroom
Real name: Kirk
Post by synthroom » Thu Dec 18, 2014 10:14 pm
commodorejohn wrote:It does seem a little odd, and if I could find a diagram for the matrix that shows which buttons are aligned on which rows I could say for sure whether it was possibly a bad connection on one of the row selects.
Yeah, check and see if there is power coming into that set of buttons. It's most likely something upstream from all those buttons that they share.
Synthetech
Post by Synthetech » Fri Dec 19, 2014 1:14 am
Are you sure the row of 4 switches above them work?
They are the other 4 switches out if the usual group of 8 using the same select line signal as the one you are having problems with.
Here's a link to schematics to see:
http://homepages.abdn.ac.uk/mth192/page ... ircuit.pdf
I suspect a problem with either C2 or C3 connectors... on either end. (From board to board)
If you have a scope, check for the pulse signal coming in on C2's red wires.
I HIGHLY SUSPECT YOUR PROBLEM IS ONE OF THESE RED WIRES... or a bad solder connection on that board that is on a trace with a connection to one of those red wires.
Using a DMM Meter's beeping continuity tester will help narrow down the problem
If they check OK, then check for return signals on C3's white, green, um.. "SB"? and pink wires when you press the switches.
rehab
Post by rehab » Fri Dec 19, 2014 3:52 am
Synthetech wrote:Are you sure the row of 4 switches above them work?
Yes, all of the 4 buttons on the top work. I will try ur suggestion when I get home from work tonight. Thank you for the help. I appreciate it
pflosi
Post by pflosi » Fri Dec 19, 2014 10:59 am
Are you sure they're not doing anything? The "internal" will do nothing since most likely you're in the internal preset bank anyways; the "cartridge" will also not do anything if you do not have a cartridge inserted. The "edit" and "function" buttons should get you to a further menu though...
rehab
Post by rehab » Fri Dec 19, 2014 1:26 pm
I am absolutely sure that none of the bottom right 4 buttons work. The "edit" & "function" buttons do not work at all. None of the memory select buttons work (4)
pflosi
Post by pflosi » Fri Dec 19, 2014 1:54 pm
Cool, just wanted to make sure that we can exclude user error. :thumbright:
