U-20 MIDI Question
Posted: Fri Jan 29, 2016 8:24 pm
I’ve had this Roland U-20 since the mid-90s and haven’t had a chance to use it that much. Consequently it is in near mint condition and appears to be functioning correctly on all levels. (looks new too!!)
I recently began using Logic Pro and hooked the U-20 up to my MacBook Pro through a MOTU MIDI interface to use with Logic Pro because I like the sound patches. To my great surprise this worked straight away. I can trigger the current sound patch from Logic Pro with MIDI notes and can play the current internal soft-synth from the U-20 keyboard and record the incoming MIDI notes in the software. Pretty easy so far.
The only problem I am having is trying to set this up so that the software will play two different patches on the U-20 from two different tracks in the Logic Pro project. As I understand multi-tymbral synths this should be something I can do with the U-20. I setup the different tracks in Logic to go to different MIDI channels. On the U-20 I set the RX on each patch to the appropriate channel setting. Unfortunately, the only sound patch I get from either track is the currently selected patch on the U-20.
The User Manual for this is frustratingly arcane and I am sure I am misunderstanding how this can be accomplished. Any insight to solve this problem would be greatly appreciated.
Thanks in advance
Thanks in advance
