Hello,
How can I connect newer MIDI controllers which only have USB connections to older vintage synth modules which only have 5 pin MIDI connections?
For example I want to use Keith McMillen K-Board (mini USB) to control my old KORG TR-Rack (5 pin MIDI). Do I need some kind of adapter like the iConnectMIDI or is this not even possible? Thanks for any help!
Connecting USB controllers to vintage synth 5 pins
ShadowImage
- Yekuku
Re: Connecting USB controllers to vintage synth 5 pins
Assuming that you dont want to use a computer, the solution is a midi usb host like this :
It is all about sharing...
- meatballfulton
- Gear: Logic Pro X
Amazed that the McMillen MIDI Expander works with all his stuff except the K BoardShadowImage wrote:I want to use Keith McMillen K-Board (mini USB) to control my old KORG TR-Rack (5 pin MIDI)
Kenton is your friend
ShadowImage
Great, that is just what I'm looking for. Shame they are so expensive but if that's what it takes...
I have four MIDI controllers, a Carbon 49, a KM K-Board, a Studiologic SL-990 and a Arturio Minilab; would they all work with this Kenton MIDI USB Host to connect to the TR Rack?
- meatballfulton
- Gear: Logic Pro X
They have to be USB class compliant. Read the manuals to see if they are.
