JD 800 Cursor buttons not working.
ronniecruisin
Post by ronniecruisin » Sat Nov 26, 2016 4:04 am
Hi. All. I have discovered another problem in my quest to restore my JD800 back to full working order. I have replaced the 6 Tac buttons for the inc yes/no unit and the 4 switch cursor page up/down unit. Now before I did this the left /right cursor was totally unresponsive. After fitting the new switches left/right is still not working. Up/down is fine. So can anyone tell me another reason it may not be working. The only other things next to the switches are the tiny resistors or whatever they are. Don't know what they do but each switch has one beside it. They all look fine (not burnt or any other visual damage), but I can't see anything else that could be causing the problem. But then, what I know about electronics you could fit on the head of a pin! Thank you in advance if anyone's got an answer. Tis the only thing that doesn't work on it. Regards to all... Ronnie.
ronniecruisin
Re: JD 800 Cursor buttons not working.
Post by ronniecruisin » Fri Dec 02, 2016 1:23 am
Hi. All. This problem is fixed.
Werecow
Real name:Brian
Post by Werecow » Sat Dec 03, 2016 10:47 pm
ronniecruisin wrote:Hi. All. This problem is fixed.
Could you post your fix, just in case others run into the same problem?
