Analog heavy Trance
- Architecture
- Gear: TR909, TR808 Dot Com, Moog LP. x0xb0x, Andromeda A6, AX60, SQ80, EPS, DSI PEK Pot Edition, ASR10, Juno 60.
- Band: Architecture!
Analog heavy Trance
wow, its probably been at least a good year or so since I have posted any tracks on this forum (maybe 2 years). Thought I drop by with a new track I am working on, its working title is DNA. Equipment used on this track
Roland TR909 for drums
x0xbox for 303 seq
Moog LP for Bassline
Roland JP8000 for supersaw
Roland JD990 for choir pad
Alesis Andromeda A6 for a short FX
and all fx's and mastering done with Ableton Live 6 plug ins.
http://soundclick.com/share?songid=7628477
x0xbox for 303 seq
ned-ryarson
Re: Analog heavy Trance
holy b'jeziz thats a tense 1...
i once told you id like to beat someone up to your 'ring of fire' number..
well i can imagine me getting beat up to this one! haha
but seriously, brilliant mix
- shaft9000
- Real name: Dave
- Gear: Whips chains and a contract.
throw yer hands up
takes me back to my first warehouse party in SanFran around '93. Except the supersaw, 'course.
i'll never forget the (not gay) couple enjoying a rowdy 69 under the stairs, bless 'em.
.svc350.memotron
.svc350.memotron
- killanator
- Real name: Carl
- Gear: Alesis Quadrasynth, Roland SH-201, Various MIDI things, Samson MediaONE 5a Active Studio Monitors
- Band: Solo
Wow, some great trancce. Thick analog sounds. Beats anything tiesto spins by a thousand, fantastic job, sounds very old school!
EDIT: posted this before the supersaw came in. makes it sound less old school, but still rocks!
The bass seems a bit to big and obnoxious in parts. It sounds like your using a mixture of waves? I normally just do 2 saws if im doing an offbeat bass in trance. You could also turn the filter down on it a bit.
The acid is great!
The acid is great!
- jaypodesta
Bangin' tune! Really enjoyed it.
that "acid line" thing really doesn't work with the rest of what you have here
god elton can't you suck
- Architecture
explain what you mean by doesnt work. off tune? off time? what.
yesArchitecture wrote:off tune?
it's dissonant with some of the chord changes you make. either it needs to change with them, or it needs to go.
- TrondC
- Gear: Machinedrum UW & Monomachine Mk2's
Korg KP3 & Zero 4 - Band: Siesta Submarina
yup, seems the acid line doesn't follow the rest (the notes entered does not match).. the rest is well produced tho, even if this is not my genere at all.. glad to hear some stuff from you btw, I was wondering where you'd been
- Overgear
- Gear: AX-73, S3000, MFC42, K5000R, K4r, K1, Nord 3R, MKS-50, Juno-106, JP-8000, CS-10, CS-15, TVS-1, PP SEM(x2), Rogue, Source, Pro-One, P-600, Mopho
I really enjoyed the track! It does seem to capture something from a couple of musical periods. I'd even say the vocal patch feels "80s sampler"
. Nice. Thanks for posting it.
I understand where mome rath and TrondC are coming from but, personally, I didn't have a problem with it. I think the line is necessary and would have to be replaced if you removed it. I don't think having it follow the bass line/chord changes would give you the outcome you want, either. That's an assumption, though.
From poking around while listening, I did notice the acid line kinda dances around the lower bass note but never hits on the two major anchor notes(the bass line). I think that might be what they are talking about.
I did have an idea, though. I thought, why not just raise(and accent?) the very last 16th note after the 8th beat, right before bass line shifts, to something like C...or vary it (over time)between a couple of notes from the chords? Maybe, that little change could help blend it with the rest of the track. You know, kinda trick the mind. Once listeners realize that little shift is gonna be there every 8th beat, the other 7 will make sense. Does that make any sense? It's just an idea that popped into my head after reading the discussion.
- Architecture
I have been having tuning issues with my x0xb0x as well, which is why I havent really used it much in my productions. I think it needs to be recalibrated, and I have a huge 1980s analog oscilloscope dying to be used to bring my Scully tape machine back to life. my tuning knob is like at 3 oclock just to get the C to be in tune. now what I have noticed too is that if I get C tuned, D will be slightly out of tune, and the upper notes its like totally out of tune. yea I know somethings not totally right with the sequence, and I think it was mostly my machine just being totally out of wack. I programed the notes to fit in the mix. It was also only a 4 note sequence too, thought Id keep that one simple. I think i could have just taken out completely during the supersaw parts as well, that i noticed did clash with the rest of the mix.
if I replace it, it will most likely be a AX-60 sequence, I made a really cool patch where I use the AX-60 for some liquid sounding sequences, assisted by a slow shallow LFO that tweaks the filter. That will be another post on here as well. Shouldnt be the tuning nightmare that the x0xb0x has been.
Thanks for the advice everyone
this case is not a tuning issue with your x0xb0xArchitecture wrote:I have been having tuning issues with my x0xb0x as well
when a chord changes in certain parts, the x0xb0x line stands out in a bad way. if it was a tuning issue, you would have this problem regardless of what the rest of the track was doing behind it
to fix the tuning of the octave spread, you will need to adjust TM5 and TM4
