Help with figuring out a sound (Chromatics "Cherry")
Come here for topics reviewing and sharing songs, tracks, music, synth demos, etc.
krp312
Post by krp312 » Sun Nov 17, 2013 7:29 pm
Hi everyone,
Brand new to this forum and sort of new to synths. I'm trying to figure out this sound which occurs at 13-14 s. in the track (the link should take you directly to the spot).
Here is a link to a clip of what I have so far. I'm using NI Massive. 2 sawtooths an octave apart, Stepper as an arpeggiator, high pass filter, slapback delay, some reverb.
I've told told that the keyboardist uses a Minikorg 700S live, however I don't know if this is helpful because he may not use this voice live anyway.
Any help is appreciated.
Thanks,
krp
krp312
Re: Help with figuring out a sound (Chromatics "Cherry")
Post by krp312 » Sun Nov 17, 2013 7:43 pm
I think what I'm looking for is what happens at 2:57 in the track--here's a link to that spot. An instrumental section begins, and that synth voice starts up again. It repeats a few times, and then on the last time (before the whole passage repeats), the voice is made bigger somehow (which takes place at 3:11). How do I get it to do that?
optimus prime
Gear: Alesis MMT8, Casio CZ-101, Korg ER-1 mkII, Korg Poly-800, Roland D-20, Roland TR-626, Yamaha DX-100, Yamaha SU-10
Post by optimus prime » Sun Nov 17, 2013 8:05 pm
Your starting point is appropriate. I'd make sure that the filter key follow is enabled, and the sound source appears to be monophonic. Also, I'd probably go with a band pass filter, rather than high pass. Not sure if there's any delay there, but there's definitely a ton of reverb. You need a short envelope on the filter too. And the oscillators sound 2 octaves apart to me, and the higher one appears to be a square wave.
The difference between the 2:57 appearance and the on at 3:11 is just different mixing, the sound was probably doubled to a track that's almost completely drenched in reverb for the 2:57 bit, then another, cleaner track comes in at 3:11, with the same audio in it.
All in all, not a simple sound to replicate. Play around with it, you might come up with a better one. :D
Great song, BTW. :)
krp312
Post by krp312 » Sun Nov 17, 2013 8:13 pm
By filter key follow, do you mean Keytracking Filter?
How would you configure the band pass filter parameters?
Thanks so much for your help!
Z
Post by Z » Sun Nov 17, 2013 8:50 pm
To me, it sounds more like low pass filter with resonance at about 50%.
optimus prime
Post by optimus prime » Sun Nov 17, 2013 8:56 pm
krp312 wrote:By filter key follow, do you mean Keytracking Filter?
Yep.
krp312 wrote:How would you configure the band pass filter parameters?
Cutoff and resonance at halfway positions, trial and error from there.
Check out this other track by Chromatics, it features a similar sound, but a bit more intelligible: It appears at the very beginning and again at about 3:30. Here it sounds like the arpeggiator is just triggering a single note, while the octave parameter is being manually tweaked, perhaps a similar approach is used for Cherry.
krp312
Post by krp312 » Mon Nov 18, 2013 8:09 am
optimus prime wrote:Check out this other track by Chromatics, it features a similar sound, but a bit more intelligible: It appears at the very beginning and again at about 3:30. Here it sounds like the arpeggiator is just triggering a single note, while the octave parameter is being manually tweaked, perhaps a similar approach is used for Cherry.
The manual tweaking of the octave parameter does seem like a good possibility for this sound. I'll try to figure this out in Massive (along with the Keytracking Filter--always wondered what that was). I really appreciate that you looked into this more!
Do you know how to get more than one octave in the Stepper?
Lastly, I pm'ed you a recording from practice tonight. :D
