Ensoniq VFX SD mainboard troubleshooting
natere2ster
Real name:Nate
Gear:Waldorf Q
SCI Drumtraks
SCI 6 trak
Korg Poly 6
Korg Poly 800 mkI
Roland Juno 106 x 2
Ensoniq ESQ-1
Casio CZ-1000
Eurorack modular odds & ends
Band:Moe Green
Re: Ensoniq VFX SD mainboard troubleshooting
Post by natere2ster » Fri Apr 16, 2021 1:14 am
Got it working! Turns out that the audio outs were toasted but i repalced the blown trace with some legs off some capacitors! The headphone out is mono (left only) but the mains work! gotta add another jumper for the headphones i forgot its got another connector (TRS) HOOOOOWWWWWWL! Sounds amazing I love Ensoniq!
Don't underestimate visual inspection! First thing to do!
Real name:Unpronounceable
Gear:Ensoniq SD-1/32,SQR,VFX,ESQm
Band:Eridani V
Post by Ashe37 » Fri Apr 16, 2021 1:43 am
check to make sure the keyboard has been bridged.
Billy Feagan
Post by Billy Feagan » Fri May 27, 2022 1:22 am
WOW !!!
what an awesome post....
I have a VFX SD that is down. will not boot at all ( blank Screen )
this is going to be a blast to read and try out all this info... and learn a but load from this..
i will try to post as i got..
bill
readymedia
Gear:TS12, KS rack, SY77, V50, T2 Turbo, WSA1, EX5, O1W/FD, JV1080, K1r, MASCHINE STUDIO+JAM, PUSH 2, ZAQUENCER, a bit of modular and other stuff...
Post by readymedia » Sat Jul 15, 2023 12:03 am
Hello there!
Thanks for a lot of information here! My VFX-SD is alive but the VFD display is dead because of leakage. The Vbb is there, a ll the chips around also get the Vbb. The 9VAC is here. The VFD is warm.
It is possible to vacuum the VFD again? At least theoreticaly? Or after leakage something inside VFD breaks for ever?
In my case only the "nose" in the middle on the top seems to be broken. Maybe it is possible to glue a kind of valve here?
Best!, Ready
Rasputin
Post by Rasputin » Wed Aug 30, 2023 11:03 am
readymedia wrote: ↑
It's dead.
The good news is that you can still find NOS of the NEC FIP80B5R display which is a bit more generic than the EPS/EPS16/ASR displays. Roughly $70 USD in 2023 which is reasonable.
The bad news is lots of desoldering/soldering is necessary, and most people will not be capable of it.
readymedia
Post by readymedia » Sat Mar 09, 2024 9:10 pm
Hola here!
Just wanted to inform you here:)
I ordered a display from US and it worked properly after I solderd it in. Sold it and finally got yn TS12 again ;)
Best!, Ready
