Korg MS 20 Mini CV Problem
AK79
Gear:RolandSH09, RolandSH2, Korg PS6, Korg700S, SolinaStringEnsemble, MFOS SoundLabUltimate, YamahaDX7, YamahaCS01,SielOpera6, Korg Mono/Poly,OberheimOB8
Post by AK79 » Thu Oct 05, 2017 4:55 pm
Hi folks,
I have problem here and maybe someone can help me out.
A client gave me a MS20 mini because he has trouble using it with external CV / Gate.
What I found after some messing around is :
if you play the MS20mini over its own keyboard you get a almost perfect scale across it.
If play it over MIDI / USB you get the same scale
If play it over the CV/GATE inputs on the panel you get rubbish. Middle C is ok but above you end up almost half a note out of tune per ovatave.
I use the Kenton pro usb and the owner of the synth has the same problem with the Arturia Beatstep.
I found that the CV output of the Kenton is pretty much what you will expect from a Hz/V scale. the Keyboard CV output of the MS20mini however is not.
I suspect that the Korgs keyboard is designed to give a scale that sits well with the VCOs - same applies to the internal MIDI/USB interface. But if you put in a normal HZ/V from whatever interface you end up nowhere.
I tried to tweak the scale on the Kenton but that did not help either.
Anybody here who could shed some light on this ? I have used the original MS20 for years with that same Kenton interface and never had any problems.
thanks
BR
Arne
