trimming a keyboard stand?
Real name:Unpronounceable
Gear:Ensoniq SD-1/32,SQR,VFX,ESQm
Band:Eridani V
Post by Ashe37 » Sun Nov 26, 2017 4:45 am
So i need a good keyboard stand sized for 61 key keyboards. I'm looking at the Jaspers 3R series of wheeled stands.
Problem is, the smallest one commonly available is the 120. I'd like the 105, but it costs *more* than the 120, and takes extra time because Thomann doesnt actually carry it.
(I'm having to give up my A-stand because its too wide to fit in my room)
Is there a way to just trim 15mm from the horizontal supports to fit?
Z
Gear:Bubble wrap, Styrofoam, boxes, packing tape
Re: trimming a keyboard stand?
Post by Z » Sun Nov 26, 2017 6:34 pm
I use USS Apache and On Stage KS-7903 stands, but I take the 48" (122cm) long horizontal beams and cut them down to 44" (112cm) to save space which leaves enough room for most, if not all, 61 key keyboards including my JP-8.
Band:Eridani V
Post by Ashe37 » Sun Nov 26, 2017 9:45 pm
How did you trim them?
Z
Post by Z » Sun Nov 26, 2017 10:54 pm
Used my electric miter saw. I'm sure a circular power saw or even a manual saw with metal cutting blade in a miter box would work, too.
Band:Eridani V
Post by Ashe37 » Sun Nov 26, 2017 11:16 pm
ok, was wondering if i needed to use a pipe cutter....
Z
Post by Z » Mon Nov 27, 2017 1:32 am
I supposed that might work, too. I just used what I had available.
pflosi
Gear:more than 150 characters...
Post by pflosi » Mon Nov 27, 2017 8:53 am
You can also order the alu tubes in any custom size from the Jaspers site. At least it was possible some years ago :)
Cheers :drinks:
Band:Eridani V
Post by Ashe37 » Mon Nov 27, 2017 9:20 am
which ends up costing even more, to someone in the states...
pflosi
Post by pflosi » Mon Nov 27, 2017 10:07 am
Yes, of course... Just wanted to point out the option :thumbright:
Fatbenelton
Gear:ModelD, Odyssey, Analog Keys, EX8000, D550, Nord 2X, KR55, MP7, TX816, Tenori-On, Kawai K5000S, Dr110&220, Argon8
Post by Fatbenelton » Sat Dec 09, 2017 3:58 pm
I trimmed my Jaspers 140-3r to around 100cm using a basic pipecutter...the ones you just rotate around the tube until it cuts through.....worked fine!
Jonny Jones
Band:Eridani V
Post by Ashe37 » Sat Dec 09, 2017 4:33 pm
thanks!
