The synth has had the old battery removed, PCB "repairs" and traces "fixed." A Panasonic lithium battery was inserted, however the synth will not save patches.
I knew I'd need to give the synth a bit of TLC to get it working well, but when I popped the hood I noticed an additional circuit board, probably a DIY job, had been added. At first glance it looks like possibly an additional storage circuit, but I can't be sure.
Anybody know what this is?
My second issue is with the resonance control. It does not effect any of the voices. No matter where the controls are set it makes no difference to the sound. The pot seems to work (I measured the resistance as I did a slow sweep) so I expect there is a problem elsewhere. I've read that ic18 can cause issues with the resonance, but all the other controls that this IC works with work perfectly.
I'm pretty handy with a multimeter, but I unfortunately don't have an oscilloscope. Will I need more than my multimeter to diagnose the problem?
Anyone else have a problem like this and can point me in the right direction?
One thing I found odd was that pins 5, 12 and 13 of IC1 on the 370 board measured continuity between them. Looking at the schematic these should not be connected as they feed pin 2 of the sustain, resonance and effect Int respectively. Am I misunderstanding that?
The 367 board looks to be in pretty good shape, and I've tested all the suspect traces for continuity, and many of the chips on the board habe already been replaced, so it would be a shame to drop 200€ on a replacement if that won't solve the problem.
Here's a pic of the added circuit
