Help!!!!
the power supply is ify at best, and the cord connector at the back of the keyboard is awlful, did some soldering works, ground appear good, but still getting some noise and hum..caps? any help would be appreciated, the pedal on the external power supply does not work, really do not need it I guess, any plans for a new build power supply would be appreciated, thank you.
Hohner/Elex K4 need info on power supply build
- madtheory
- Real name:Tomas Mulcahy
- Gear:Wurlitzer Opus 1536, Model F, Morovdis Arpeggiator, Maplin My First EQ, Jeff Wayne Thunderchild rack, Thermostat, Buck Owens' Moog.
Re: Hohner/Elex K4 need info on power supply build
You will need an oscilloscope to check for ripple in the supply. Likely the caps, yes, but could be rectifiler fault too. Don't guess. Test.
- adamstan
- Real name:Adam
- Gear:Yamaha 2xDX7II|QY-70|PSR-S750|PSR-2000|TYROS|Electone D85|Electone E50
B5 DIY polysynth
KORG Poly61
Vermona DRM
Solton Programmer 24
LEMA EDD-5 - Location:Poland
My Elex was humming too, but the bad capacitors weren't in the PSU - they were on chorus boards.
Man with a tape recorder | Living in the '80s
