I have a problem with my odyssey mk2 2812. When depressing a key it makes a noticeable click/pop noise. It’s pretty subtle when playing with the filter open but whey doing more smooth sounds it’s very audible. Raising the attack in adsr does help but I have to raise it very high to get rid of it. The noise is still present when turning both VCA sliders down. I’m thinking this isn’t normal? I saw this thread, and it seems like a similar problem: viewtopic.php?f=5&t=37658
I have recapped all boards and the psu, put in new ics and properly cleaned all sliders. Can someone with a vintage oddy try this and see if it’s the same?
Thanks
ARP Odyssey click/pop noise
Re: ARP Odyssey click/pop noise
Sounds like the VCA bias not calibrated. Isn´t there a trimpot for this?Joens wrote:I have a problem with my odyssey mk2 2812. When depressing a key it makes a noticeable click/pop noise. It’s pretty subtle when playing with the filter open but whey doing more smooth sounds it’s very audible. Raising the attack in adsr does help but I have to raise it very high to get rid of it. The noise is still present when turning both VCA sliders down. I’m thinking this isn’t normal? I saw this thread, and it seems like a similar problem: viewtopic.php?f=5&t=37658
Thanks
Herrare umanum est.
I have calibrated the whole synth also .. didn’t help with the vca gain trimpot
It´s the bias, not the the gain. It´s the trimpot labeled T2, if I´m looking at the right schematic...
Generally the VCOs level turned all the way off, LPF fully open and the VCA set to maximum. The trimpot then adjusted for lowest "thump"...
Herrare umanum est.
Turning the vca cvr trimpot helps to get rid of some low end “thump” indeed.
