I´m OK with this mess because we´re having a conversation, not releasing a finished technical paper for public scrutiny.
Now why is C14 the cap responsible for widening the low end of the pass band?
A band pass filter is a low pass with a high pass, cascaded. In what order doesn´t matter.
C14 is the HPF, C13 is the LPF.
VR4 is what determines the type of filter. With wiper in the middle, nothing gets through C14, because it´s a mix of the original signal with the same signal inverted by IC1 at unity gain. The levels being equal, both cancel each other out. So the mid position is, I believe, zero.
Moving the wiper towards IC1, C13 sees the inverted signal at full level while the original signal is fully attenuated.
C14 acts as an HPF, C14 as an LPF, the filtered signal returns to IC1 via the non inverting input and in phase with the opamp output. The result is true band pass filter.
Moving the wiper away from IC1, C14 sees the original, non inverted signal at full level, while the inverted signal is fully attenuated.
C13 and C14 still act as LPF and HPF respectively, but now the filtered signal entering the non inverting input is out of phase with the opamp output, because it´s derived from the original signal and maintains its coherence. Mixed with the inverted signal at full level, what was an HPF becomes an LPF and vice versa. The result is a band reject filter.
I hope this makes sense
