Hey folks. Am trying to resuscitate a Crumar Performer and have run into a few issues. When I first tested it, everything worked except for Middle C, but all of the sliders / potentiometers were sticky / crackly etc. So, one by one, I desoldered the sliders and cleaned them with Deoxit F5, then sprayed with Deoxit F100, and then re-soldered.
When I tested it again, it seemed like all of the sliders had cleaned up nicely, but there was full sustain on the Strings, regardless of the position of the slider, and maybe the response of the Volume of the string section wasn't quite as smooth as it should have been despite the slider moving properly. On closer inspection of the Sustain slider, I noticed that solder had actually dripped into the slider itself when I was re-attaching to the board - I made a real mess of it while trying to get enough solder to cover some of those bigger wholes, and possibly, I've inadvertently joined solder points on both, the Sustain and Volume paths (not to each other, but possibly to other points on the same respective paths), am wondering if this is the cause of my full sustain issue, as well as the volume issue. Does anyone have a picture of the String board so I can see if my solder points look the same?
Meanwhile, the full sustain issue seems to be affecting the Brass section as well. Is this a function of the bad String section Sustain? What happens is, if I play a key and release, when I hit another key, the original note sounds along with the new key, and this repeats for each successive key / note added, until any given note would decay as if sustain were set to full.
Somewhat interestingly, at least to me, is that when I press on the otherwise dead Middle C, whatever notes I had pressed previously and quickly released (as in not holding long enough for them to sustain and decay as described above), will sound when Middle C is held down. Am I right in thinking that the problem with Middle C is not the contact? I opened up the keyboard and the key mechanism appears to be functioning properly, same as all of the other keys - I sprayed the key contact with Deoxit F5 - but again, since it's triggering the previously hit (yet not decayed) notes, I'm guessing the contact isn't the issue?
As you've likely surmised, I have no idea what the h**l I'm doing, so any advice, in novice terms, would be greatly appreciated.
Thanks!
Crumar Performer - dead key and full sustain issues
Re: Crumar Performer - dead key and full sustain issues
Update... on closer inspection, it turns out that the wire that is supposed to be soldered to the orange bar (running from left to right underneath the keys in this image) for Middle C was disconnected from the solder. So that will hopefully resolve the Middle C issue.
http://www.mensuhell.ciboire.com/sound/crumar-03.jpg
Back to the full sustain...
