I've been lurking here forever and want to make the jump.
Here's my deal - I'm in a Pavement-ish band, but I want to add some synth into. I really like the idea of being able to put down a line within a sequencer in the synth within that context.
I'd also like the synth to have good midi implementation so that I can use it to control something like Mainstage for more versatility (assuming that I will likely start out on a mono).
Things seem to be pointing to a Novation Bass Station 2 at the moment. I've read midi implementation on the Monologue isn't the best. Thoughts?
Best beginner synth w/good midi implementation
scotnewon96
- meatballfulton
- Gear: Logic Pro X
Re: Best beginner synth w/good midi implementation
As long as a 25 key monosynth will do the trick, the BSII has the best MIDI implementation of today's lower priced monos plus it's not as limited as the Monologue. You can always had a larger (49, 61) controller-only board for Mainstage and polyphonic playing if you need it down the road.
