Yamaha cs50
claudiopallone
Hi guys.
I don't know if I have done a great or a really bad deal.
This morning I bought a Yamaha cs 50 in marketplace.
It was going for 50Euro (wtf) because not in working condition. I have quickly agreed with the seller to get it for 600 Euro because I knew he would get bombed. So I closed the deal.
I went to get it, looked inside and at least it didn't look empty haha. It seems like the main parts should be where they are. I am no expert and that's why I m here, but the biggest flow I could see is that all cables going to the keys had been cut.
Now before I give you photos and before I know that it could be other 100 problems other than this, I would like to ask you. Why do you think the previous buyer had cut all cables going to the keys ? What project did he have in mind ? I am asking because I think that could help figure out what other kinds of problems the machine has.
I thank you in advance for your help and sorry for my English
All the best .
Claudio
All the best .
Claudio
- madtheory
- Real name:Tomas Mulcahy
- Gear:Wurlitzer Opus 1536, Model F, Morovdis Arpeggiator, Maplin My First EQ, Jeff Wayne Thunderchild rack, Thermostat, Buck Owens' Moog.
Re: Yamaha cs50
Preparing it, in a very rough and brutal way, to be sold for parts?
claudiopallone
Re: Yamaha cs50
Oh no ...
Why do you say so
Why do you say so-
claudiopallone
Re: Yamaha cs50
Mmm... would you start by cutting those ?
I can't be that they have been "dragged off" accidentally by lifting the keybed ? Still haven't had time to look at it but I saw that the keyboard could be lifted / removed without removing the main panel ?
- madtheory
Re: Yamaha cs50
Because the CMOS chips will be rotting by now. The key assigner is a common failure. Only way to get one is break another CS poly. If you are lucky, you can bypass the key assigner with the Kenton retrofit kit. Play the synth via MIDI only.
A photo would tell.claudiopallone wrote: βThu Mar 11, 2021 6:40 pmI can't be that they have been "dragged off" accidentally by lifting the keybed ?
claudiopallone
Re: Yamaha cs50
I could finally look inside a little , and even though my poor expertise I kind of feel I have just thrown 600 Euro in the water. Could some expert tell me a little more here? I get zero sound from outputs obv
Here the photos https://drive.google.com/drive/folders/ ... cq7-P7Q39s
All the best .
Claudio
All the best .
Claudio
claudiopallone
Re: Yamaha cs50
I ve got some information from the seller , he said that the owner 20 years wanted to use the keys for another project but never he never kept going so could be that the rest is in shape
- ppg_wavecomputer
- Expert Member
- Gear:more keys than hands (and feet)
- Band:['ramp]
Re: Yamaha cs50
Because truth always hurts, and reality tends to bite back viciously.
In Yamaha custom parts parts alone, it would easily be worth three or four times the price you paid for it. After all, more CS50s than I care to admit were cannibalised for parts to make their bigger brethren survive.
One major and very common pitfall with CS polysynths are the 4XXX CMOS ICs as well as the keyboard assigner ICs. The latter can be salvaged from some contemporary top-of-the-range Yamaha organs if space is not an issue for you. I had all the 4XXX ICs replaced as well as various capacitors and tantalum caps some years ago, just to make sure they would not get me in trouble eventually.
Unfortunately, I can't blow up the photos and have a closer look at what is inside but it looks reasonably complete.
This is yet another story of an apparent bargain turning sour.
Stephen
https://ramp1.bandcamp.com/
claudiopallone
Re: Yamaha cs50
ppg_wavecomputer wrote: βFri Mar 12, 2021 8:48 amBecause truth always hurts, and reality tends to bite back viciously.
Stephen
Thanks for the reply! It seems like what's missing are the KAS and SH cards below the keyboard. Will they be hard to find ? In case I would like to sell it in parts, where would you recommend doing that ? Thank you in advance
- madtheory
Re: Yamaha cs50
It's cosmetically perfect, and no signs of corrosion, even the caps I can see look minty. I notice some tomfoolery on the PSU. I doubt those parallel resistors are factory. But I could be wrong. But the soldering is horrible.
If you want to use it as an instrument, contact Kenton. I am pretty sure their retrofit bypasses the KAS. But ask them.
Yes.
Reverb.com, Ebay.claudiopallone wrote: βFri Mar 12, 2021 3:39 pmIn case I would like to sell it in parts, where would you recommend doing that ? Thank you in advance
- ppg_wavecomputer
- Expert Member
- Band:['ramp]
Re: Yamaha cs50
I strongly endorse trying the Kenton option first before gutting the instrument -- the lure of quick profit, I know.
Stephen
Stephen
claudiopallone
Re: Yamaha cs50
ppg_wavecomputer wrote: βSat Mar 13, 2021 11:19 amI strongly endorse trying the Kenton option first before gutting the instrument -- the lure of quick profit, I know.
Stephen
One local technician told me that the midi implementation won't work without those boards...I Think I will give it a try anyway.
- synthRodriguez
- Real name:Scott
- Gear:Moog - Roland - Yamaha
Re: Yamaha cs50
You need all the original boards and a working synthesizer for the Kenton system to work, it piggybacks onto the key assigner. Without the KAS and SH cards, it's useless.
If all the Yamaha chips are on the voice cards, I'd say you got a good deal. I certainly would have snatched it up for $600. It's really not that bad if you know what you're doing and the only thing that is missing is the two boards.
Would love to get it working for you, too bad I'm in the states.
- ppg_wavecomputer
- Expert Member
- Band:['ramp]
Re: Yamaha cs50
I'll have a spare voice board then. Or maybe two, if the price is right.
Stephen
Stephen
