Hello all,
My name is Artur and have a chance to buy Yamaha Cs1x synth and QY300 sequencer in very good condition.
Just wondering what those two can do together?
Thanx
Yamaha Cs1x and QY300
Re: Yamaha Cs1x and QY300
It depends what you want to do. The QY300 is a capable sequencer and had the GM midi sounds in it. You can use thr CS1X to sequence music either using the sequencer sounds or the sounds of the CS1X itself.
- Zamise
- Gear:Rollhand P00
- Band:Quantum-Source
CS1X is kind of a c**p synth to be up front. It is useable as a pretty decent midi controller. If you get that then it is made to hold a QY70/QY100 sequencer on the shelf on the right side of it, so I think I would prefer a QY70 with it instead of a QY300. The CS2X sounds a bit better but also kind of a c**p synth that has shelf for the QY70. An AN1X also has a shelf and with a QY70 would be the best ticket
