soundcard advice
hashy
soundcard advice
Post by hashy » Tue Dec 05, 2006 12:50 pm
Im about to purchase my first music making pc (DELL dual core/4GBram)
would anyone reccomend a good analog sounding card? I wish to use 5 arturia programs in a real time situation...Im not a fan of latency either - 0% if poss :) I cant play if aint on the button :(
I will aslo be using a couple ogf 'real' synths too.
thanks
#e
THM
Gear:ARP 2600
Elka Synthex
EML Polybox
EMS SynthiAKS
mTron
MOOG Mini- & Memorymoog
Oberheim SEM
Roland Jupiter-8/...
Yamaha CS80
DotCom
>see MySpace
Band:THM
Post by THM » Tue Dec 05, 2006 1:33 pm
You'd have a look at the MOTU site; the MOTU cards are used by a major part of the professional home producers. MOTU has a big serie of HQ soundcards; check the specifications and choose the one you think it will most suit with your setup. I mean check power, if it is compatible with your OS and programs, if it has analog in- and outputs (and how many; depending on your wishes). Enjoy !!!
PS: If you don't find your card there, maybe you should consider a whole Digidesign ProTools setup - like in most "big" studio's - but that will be way more expensive if you want an entire setup. I'd definitely have a look at the MOTU homepage first...
DotCom Modular * ARP 2600 * Elka Synthex * EML PolyBox * EMS Synthi AKS * MOOG Minimoog Model D, Memorymoog * Kurzweil PC88 * Oberheim SEM * Roland Jupiter-8, JP-8080, Juno-60, TR808, TB303, MKS50, RE301, SDE330, SRV330 * Yamaha CS0 * see THM on MySpace
hashy
Post by hashy » Tue Dec 05, 2006 1:34 pm
THM wrote:You'd have a look at the MOTU site; the MOTU cards are used by a major part of the professional home producers. MOTU has a big serie of HQ soundcards; check the specifications and choose the one you think it will most suit with your setup. I mean check power, if it is compatible with your OS and programs, if it has analog in- and outputs (and how many; depending on your wishes). Enjoy !!!
cheers man :)
valdiorn
Post by valdiorn » Tue Dec 05, 2006 1:38 pm
M-Audio makes some cheaper (yet very good and reliable) alternatives as well...
http://www.myspace.com/notindemand
Life's a b***h, get a f**k helmet!
_________________
fingerbib2000
Re: soundcard advice
Post by fingerbib2000 » Tue Dec 05, 2006 1:40 pm
hashy wrote:Im about to purchase my first music making pc (DELL dual core/4GBram)
thanks
#e
you can't go wrong with creamware DSP cards, plus, they're compatible with all the creamware VA synths, which are the most analogue sounding synths i've heard. best piece of gear i ever bought.
www.creamware.com
Sequential Circuits Pro-8, Rolands TB-303, MKS-80, JX-8P, SH-09. Waldorfs Microwave XT, Pulse. Yamahas RS7000, A4000, DX-200. 2 x Cheetah MS-6. Novations Supernova 1 & 2. Korg ER-1. Creamware Pulsar 2.
ambientlive
Post by ambientlive » Tue Dec 05, 2006 7:05 pm
hi there hashy
Matrix 1000, A-Station, E5000, MicroKorg, Kawai K4, TC M300, DFX12, Shuttle
konvert
Post by konvert » Tue Dec 05, 2006 10:00 pm
And yet another suggestion: E-MU. I use E-mu 1820 and I'm very happy with it.
Also I've had M-Audio card.. Delta 44. I reckon they don't make them anymore but I was satisfied with it when I got it.
So I can recommend M-Audio also.
Both E-Mu and M-Audio are on the cheap side of audio-music-making-cards but they work.
I suggest do not go overkill and pay yourself sick because it's not necessarily very cost-wise. You can always upgrade later.
Just make sure whatever you get, you get one with enough inputs/outputs.
Vermona DRM1 mk2, Casio CZ-1000, MaM VF-11, Boss PC-2, Korg Minipops Junior
hashy
Post by hashy » Wed Dec 06, 2006 9:39 am
ambientlive wrote:hi there hashy
Hello Mr S
a small world :)
jasedee
Post by jasedee » Wed Dec 06, 2006 11:27 am
thanks
#e
*The MOTU drivers are more optimized for Macs than PC's...
*M-Audio make shite
*Depending on your needs, digidesign may have an LE interface that will suit you
*RME would be your best bet, but they can get pricey...
Good luck!
l::l CS-10 l::l DX7 mkIIFD l::l Motif Rack l::l D-50 l::l Juno 60 l::l Virus Rack XL l::l ER-1mkII l::l TR-707 l::l MC-303
MYSPACE
WWW
MrHope
No Longer Registered
Post by MrHope » Wed Dec 06, 2006 5:51 pm
I have an M-Audio 2496 Audiophile. I bought it used for 90 dollars including shipping. It's a 24bit 96kHz stereo soundcard with digital I/O and MIDI. It has clear sound and is very easy to use. It has low-latency ASIO drivers.
My only complaint about it is that I had to download the drivers from the M-Audio website because the installer didn't work at first. However, the downloaded installer worked just fine.
I would recommend this card. It doesn't sound analog; it doesn't sound digital. I just sounds clean. It doesn't add or subtract from the sound you put through it. It just does what it's supposed to do--record and play high resolution sounds.
If you want a so-called warmer sound, record through an EQ or a low pass filter to take the upper end off.
Something that could also yield interesing results is occasionally recording through a compressor/limiter to
get a hotter sound without such steep peaks.
rdemon
Post by rdemon » Wed Dec 06, 2006 8:02 pm
I have the M Audio 2496 as well and it sounds clean and i'm happy with it. I'm going to be getting a new sound card with more in/outs (probably the Delta 1010LT) because I use a lot of external analog effects with sounds generated from the computer.
I was looking at getting a more expensive MOTU interface ($800) but I did not feel i'm getting more for my money ($200 for 1010LT).
I'm not sure about the quality of the A/D, D/A converters. I haven't found anything that says the higher priced sound cards have better quality converters (ie. better enough so that it makes a signficant difference in sound).
Ronald
Gear:Eurorack, RYTM, Ultranova, many FX
Post by Stab Frenzy » Wed Dec 06, 2006 10:26 pm
jasedee wrote:*The MOTU drivers are more optimized for Macs than PC's...
*M-Audio make shite
Good luck!
Second everything here.
konvert
Post by konvert » Thu Dec 07, 2006 5:28 am
I want to hear facts why M-Audio makes shite.
Post by Stab Frenzy » Thu Dec 07, 2006 5:49 am
Maybe no hard and fast facts, but compared to Motu and RME products, and even Digidesign, their hardware is poorly made. They use a lot of plastic instead of metal, the connectors are cheap and often unbalanced. Add to that the fact that their drivers are shocking and you've got enough problems to say M-Audio products are shite.
konvert
Post by konvert » Thu Dec 07, 2006 6:44 am
Stab Frenzy wrote:Maybe no hard and fast facts, but compared to Motu and RME products, and even Digidesign, their hardware is poorly made. They use a lot of plastic instead of metal, the connectors are cheap and often unbalanced. Add to that the fact that their drivers are shocking and you've got enough problems to say M-Audio products are shite.
True.
But those products you mentioned are waaaay more expensive than M-audio so they really can't be compared.
I don't want to argue here, I agree with you (though I don't have experience of said cards) but one must think is it relevant to buy the most expensive card(s) there is. Maybe it is, I don't know.
