Quadrasynth's display lit but blank; all else dead
jerry aldini
I have an original Alesis QSynth + Piano, circa 1995-6. Has always worked fine. I power it up the other day and the display is lit, but no characters. No sound, no kind of response from anything. I opened it up, no obvious loose connections, burnt boards or anything.
Any suggestions as to what might be the problem? Thanks.
- Maschinengeist
- Real name: Steph. J
- Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
Have you checked the fuses? First step.
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
MuzikElektronix.com
Help? See TechZone
Parts? email!
- Stab Frenzy
jerry aldini
I replaced the one fuse I saw when I pulled it apart, but there may be others (maybe on the other side of one of the boards. Guess I need to pull them to see the other sides.
Yes, it does use a wall wart, I'll switch it out with a different one in case this one's gone bad.
Thanks for the replies, I'll let you know what I find out.
- Maschinengeist
- Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
If I'm not mistaken, QSynth also use chip fuses. Labeled as FU (usually). They test like normal glass fuses.
There shouldn't be not fuses on the "other side of the board". All the fuses are on the printed side, not on the trace side.
The ac adaptor is a possibility... but I've got my reservations. But Stab might be right.
MuzikElektronix.com
Help? See TechZone
Parts? email!
MuzikElektronix.com
Help? See TechZone
Parts? email!
jerry aldini
Thanks for the info, Maschinengeist. Would they be soldered in?
Does the Qsynth have any kind of internal battery? I saw a battery for later Alesis synths on eBay and it got me thinking that IF it had a battery, it could certainly be gone after 12 years. And if it died, it simply would have lost everything, meaning I'd have to replace the battery and then replace the "software"?
Again, I didn't see anything that looked like this battery inside my Qsynth, but that was before I knew what little I know now.
- Stab Frenzy
jerry aldini
- Stab Frenzy
MrHope
- No Longer Registered
jerry aldini
Thanks, MrHope. I tried the reset during powerup, but got nothing. I've been reading up on some stuff and I found schematics online. I'll open her up again this weekend, so maybe I'll have some more intelligent observations and questions next week.
I'm also saving some cardboard, thinking I might have to box her up and send her up to you in Canada, Maschinegeist.
