MS2000 setting up Split/Dual mode
You`ll notice that when you shift to dual/split mode the "select timbre" controll becomes active, and the right part of the keyboard is controlled by timbre 2 vs the left side on timbre 1 (in dual mode)... But as far as i know, you can`t load a preset into the new timbre. You`ll just have to tune it the way you want it. Hope it helped although the reply is a bit late
Korg MS2000B, Korg Electribe MX, MAM MB33mkII, Moog LP Tribute
