Arturia Moog Modular
riccir
Post by riccir » Wed Aug 15, 2007 2:10 am
hearttimes wrote:i like that bode shifter on the mmv. god knows what it does.
Well I could tell you what it does ... shifts the frequency content of a signal in a linear vs. exponential/harmonic fashion. But common uses for it, well that's another matter :lol:
hearttimes
No Longer Registered
Post by hearttimes » Wed Aug 15, 2007 2:12 am
well at the high price, seems you got to hook it in.
hearttimes
Post by hearttimes » Wed Aug 15, 2007 2:13 am
besides, it looks damn cool.
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Post by Bitexion » Wed Aug 15, 2007 2:20 am
Here's AS' version of it
Very expensive module, will never afford it.
Here's a link to its manual, the Moog one functions in a very similar way so you might get some pointers. It's PDF, so you need a free reader like adobe acrobat reader to see it.
http://www.analoguesystems.co.uk/pdf/RS240.pdf
"A frequency shifter is a highly specialised module capable of shifting the spectrum of a signal by a fixed
amount. This is very different from a pitch-shifter and other effects such as ring modulation or frequency
modulation. (See appendix 5.)
The RS240 allows you to shift the frequency linearly within a number of ranges, the widest of which
shifts the signal by approximately ±5kHz at its maximum setting. You can use manual and voltage controls
(or a combination of the two) to achieve the desired effects. Upwardly shifted and downwardly shifted
signals are available simultaneously, both as independent signals, and as a user-defined mix of the two.
This module also allows you to shift the frequency exponentially, which will produce a number of
conventional - and less conventional - pitch shifting effects."
Here's the natty sequencer I want for mine:
http://www.analoguesystems.co.uk/modules/rs200.htm
gearaddict
Post by gearaddict » Wed Aug 15, 2007 5:16 am
does anyone have any sound samples of things they've gotten using the software synth? I'd really like to hear what you guys have patched up!
Jordan H
Gear|Addict Clothing
(Designer/Creator)
Unique synth/audio/recording clothing for adults and kids
http://www.cafepress.com/gearaddict
Soundwave
Post by Soundwave » Wed Aug 15, 2007 3:31 pm
gearaddict wrote:does anyone have any sound samples of things they've gotten using the software synth? I'd really like to hear what you guys have patched up!
I did this cover of Oxygene 5 a while back using just the MMV v1.2.
http://www.mediafire.com/?evhxt1x0gss
hearttimes
Post by hearttimes » Wed Aug 15, 2007 4:40 pm
fine work rob.
Bitexion
Roland D-50
Creamware Minimax
Yamaha DX7s
Post by Bitexion » Wed Aug 15, 2007 5:59 pm
Would you mind sharing the soundbank you made for those sounds?
I'd like to see how they were made, that's all. Learning experience :)
chamomileshark
Post by chamomileshark » Wed Aug 15, 2007 7:37 pm
I used the MMV2 alot, I started with the MMV1. It made me get a hardware modular!
I too found the mixer confusing, I found it didn't sometimes work or maybe it was just me. The sequencer can be a bit flaky when MMV2 is reloaded.
I used MMV2 for the main sequence (using the Bode Freq Shifter) and the shimmering lead line (using the ring mod). Possibly the rain is also MMV2, can't remember
http://www.soundclick.com/util/streamm3 ... 54126&q=hi
Soundwave
Post by Soundwave » Wed Aug 15, 2007 10:48 pm
Bitexion wrote:Would you mind sharing the soundbank you made for those sounds?
Sadly the patches were lost during the upgrade to V2.0 and they were saved on my old PC which has long gone kaput. :(
I'll try to do some more Jarre covers in the future its good practice and easy to do with the MIDI file all ready.
Bitexion
Roland D-50
Creamware Minimax
Yamaha DX7s
Post by Bitexion » Mon Aug 20, 2007 3:52 pm
On a slightly off-topic note, I found a site with tons of Jarre midi files.
Might not be the easiest to make the correct sounds for each midi track since you didn't build the file yourself, but saves lots of work for those who don't want to figure out all those complex chords he uses.
http://membres.lycos.fr/blobwars/midi/
MarkM
Post by MarkM » Mon Aug 20, 2007 6:20 pm
Here's all I have easy access to. It's a very simple sequence, but it's very Moogy sounding:
http://www.limitedwave.com/subterraneou ... Flight.mp3
deb76
Post by deb76 » Sat Nov 03, 2007 2:43 pm
With Ems Synthi Avs, the Moog Modular V2 is my favorite synth.
Here, a long progression often carried out with the Moog Modular V2 :
http://www.d758076.eu/MP3/MoogMontFreqVCATrig.mp3
Here, 3 videos with Moog Modular V2 with a patch to work continuously with the MMV :
http://fr.youtube.com/view_play_list?p=1632E5A9F605BBF5
Origin Arturia, Yamaha SY 99 & EX5R, Evolver, G2 Engine, Stratocaster Roland midi, AudioSculpt & Open Music of IRCAM, Moog Modular V2, Prophet VS, EMS Avs, Tassman 4, Arturia Brass, Max Msp 5, Fireface 800. http://magelectrique.blogspot.com/
riccir
Post by riccir » Wed Feb 27, 2008 10:52 pm
Hey .... so first: yes I did RTFM but yet I'm still stumped on this one:
How to send an audio signal through the Efx version of the plugin? I use the "In" which is on the same row as the modulation ins, but I can't seem to get anything coming through.
Also, I thought the VCA needed to be open, so I tried triggering a long note while sending audio through, still no luck.
How does one get this to work? I'm using the Audio Unit "Moog Modular V Efx" in Ableton Live, for what it's worth.
Thanks, dudes! 8)
riccir
Post by riccir » Fri Mar 07, 2008 1:02 am
no help? :oops:
