MFB II + Quasimidi 309 Users???
Kaled
Post by Kaled » Mon Oct 15, 2007 3:25 am
Does any one know if you can control the gate time on individual steps of either Quasimidi's 309 or MFB's Synth II? I am not sure if I am even using the correct term. What I mean is the length of individual steps in a pattern. I once had a DX200, I think that is what Yamaha called it. Thanks is advance.
Gear: TB-303, MC-505, MC-09, V-Synth GT, FR-777, FR-XS, MFB: Synth II, EMU Proteus 2500/CS, FS1R, Supernova II, Fusion 6HD, ER-1 MKII
Band: 23, A23P, Piss Ant
Re: MFB II + Quasimidi 309 Users???
Post by 23 » Mon Oct 15, 2007 7:27 am
Kaled wrote:Does any one know if you can control the gate time on individual steps of either Quasimidi's 309 or MFB's Synth II? I am not sure if I am even using the correct term. What I mean is the length of individual steps in a pattern. I once had a DX200, I think that is what Yamaha called it. Thanks is advance.
In regard to the Synth II, with it's own sequencer, NO.
With an external unit, most definitely (through either CV or MIDI).
But it's own sequencer squeezes out a base 16th note; which can be multiplied through sustained 16ths....but everything is going to end up at least a 16th or some whole division of a 16th (when larger than a 16th).
Soundwave
Post by Soundwave » Mon Oct 15, 2007 9:47 am
On the 309 you can alter the note length/gate on the bass sequencer to 4 different user definitions but on the percussion its fixed as you don't really need it.
