ensoniq esq-1 programming
Post by 690288001 » Fri Nov 09, 2007 7:05 am
i have figured out how to modify existing programs, and save them, but i would like to know how to start a program from scratch. saving it over an existing program is not a problem.
thank-you very much
Yoozer
Post by Yoozer » Fri Nov 09, 2007 7:40 am
If there's no procedure to "initialize" a patch, you have to do it yourself. Simply disable all the LFO routings, set the filter to bypass or set the cutoff to max, only enable 1 oscillator with sawtooth or pulse, reset all coarse/fine tuning and disable the effects. Then save this in a remote location you're not prone to overwrite quickly - like the last preset in the bank - and you're done.
