MPC 500
thestreets
Gear: Maschine Mikro, Electribe ESX, KP3, Korg R3, Microkorg.
MPC 500
Post by thestreets » Thu Nov 15, 2007 11:49 pm
I believe I'm going to be getting one? Is it a good unit?
Comment strictly on the 500 if you please and don't offer substitutions because they just aren't gonna happen. I'd be getting an ill deal on the 500 only so i just need some feedback on that one.
THanks
The Streets
esqoner
Post by esqoner » Thu Nov 15, 2007 11:51 pm
small and batteries = badass.
use it learn it it will be great
JSRockit
Post by JSRockit » Fri Nov 16, 2007 7:15 pm
I use one and love it... the menu diving takes a bit of getting used to vs. the older machines...but once you are used to it, it is so much more capable than something like a SP-303 or SP-404. Plus, it is 2lbs and battery powered. It is the most feature packed battery powered drum machine I can think of.
thestreets
Post by thestreets » Tue Nov 27, 2007 10:44 pm
Can you adjust the tempo of a sample without affecting pitch?
thestreets
Post by thestreets » Mon Dec 03, 2007 12:26 am
Word?
Anyone know?
space6oy
Post by space6oy » Mon Dec 03, 2007 12:33 am
esqoner wrote:small and batteries = badass.
i agree w/ that.
negatives you should be warned of are that it only has a stereo out instead of any individuals and it can't do the loop cutting & stretching that its big brothers do.
thestreets
Post by thestreets » Mon Dec 03, 2007 2:57 am
woah woah woah....
You can't chop up loops on the 500?
There's no way thats right....
If you mean you can't visually see the waveform during chopping...then whatever...i have a good ear. I'm pretty sure you can still actually chop up a sample.
space6oy
Post by space6oy » Mon Dec 03, 2007 3:28 am
no, you CAN chop up samples manually, but the 500 doesn't have the time adjustment for loop samples...can't think of their terminology for it right now, but you can look it up in their manuals. just check out the 1000 in comparison. the big bros can automatically cut up a sample so that you can set that sample to match the length of a loop regardless of changing tempos. keeps the sample's pitch the same regardless of speed.
Post by Stab Frenzy » Mon Dec 03, 2007 3:44 am
Akai call it patched phrase.
space6oy
Post by space6oy » Mon Dec 03, 2007 3:54 am
Stab Frenzy wrote:Akai call it patched phrase.
patched phrase! thanks.
thestreets
Post by thestreets » Wed Dec 19, 2007 6:30 am
I'll give this question a try in this thread I suppose.
When you play samples on the MPC (especially instrument samples) does the audio over lap when you hit the pads? So say if you have a chopped sample and the hits run for a few seconds each, will the sustain start to run everything together, or does the sample from a pad cut out when you hit another?
hageir
Gear: http://www.geirhelgi.com/
https://soundcloud.com/geir-helgi
Band: Geir Helgi
Post by hageir » Wed Dec 19, 2007 3:13 pm
thestreets wrote:I'll give this question a try in this thread I suppose.
there's a mono/poly button for that:
mono = "stops" the sound (itself) thats already playing
poly = "overlaps", when you have long samples it can get pretty annoying :)
I know, I know:
but seriously, for $100 more you can get yourself the 1000
and $30 more you can get the JJ os, which is NUTS!
http://translate.google.com/translate?h ... ls%3Den-us
MnM MD UW MEK Prophet REV2 16 Chroma Polaris K3 VFX ESQ-1 Odyssey Böhm Digital Drums Wavestation WS-1 MS-20 DPX-1 VZ-8m C1 Music Computer Synare PS-1 JX-3P E-MU MPC 2000XLSE-1X Polysix red SH-101 CR-8000 KPR-77 CS-15 SH-5 Matrix 6R
thestreets
Post by thestreets » Wed Dec 19, 2007 6:44 pm
Can you have mono and poly in certain parts of each program? I imagine you would want poly for drums and mono for most samples.
Also, the 500 is $600 and the 1000 is...well, $1000. Where could i get it for 100 more?
I got recycle so i really don't see it as too much of a problem.
JSRockit
Post by JSRockit » Wed Dec 19, 2007 7:13 pm
thestreets wrote:Can you have mono and poly in certain parts of each program? I imagine you would want poly for drums and mono for most samples.
They are talking about used prices... I'm selling a used MPC500 for $425. They can be had cheaper...if you don't care about manuals, power supplies, original boxes etc.
thestreets
Post by thestreets » Wed Dec 19, 2007 9:33 pm
Thing is I'm asking santa :wink: for the MPC so I'd rather do retail rather than the 'bay.
