They are quite similar, useful example.OriginalJambo wrote: Here's a little example. First the PolySix then the Mono/Poly playing the same sequence with both key trigger settings. No external effects have been used.
The other side of the medal.tom Cadillac wrote:I rather like the unison/share mode - in fact its the mode i usually use. What i like is that when you play lots of notes there's a randon element introduced as the next oscillator is triggered and another dropped - I usually have the oscillators at different wavefroms and pitch for thickness and thus the sound becomes wonderfully complex and intreging. This for me is what makes the Mono/poly really special - four different oscillators all firing away, sometimes together and sometimes in strange new patterns. What other synth does this? ?![]()
As to effects - I think the metasonix TM1 is the best I'v found to add externally - but I don't really think its needed. OOOOh and the point with that filter where you start to wind the sound out from deep silence!
