Hi all,
My 727 finally arrived, minus a working lcd screen which I"m pissed about. Been racking my brains as to how to sync these bad boys together..
The manual aint much help, and I'm getting frustrated, can you guys lend a hand please? And maybe explain how it all works.
I've tried DIN with no luck, might be the cable...
Arrrg
Cheers.
Syncing tr-707 to tr-727
- Stab Frenzy
It'll work fine with either dinsync or midi, just make sure you've got the out to the in and the master is set to send and the slave to recieve. That might be a bit tricky with a busted LCD, but just keep trying different combonations on that one til you figure out what it's set to.
It's all in the manual, which you can download from Roland.
