Well... Sunsyn is really picky about the incoming MIDI signal. Some controllers and sequencers cause undesired behaviour like false triggering of notes, notes getting stuck, etc. For example, if I control the Sun with my Motif, every couple of minutes a note can suddenly shoot to the upper octaves, or get stuck. With my M-Audio controller, zero problems. If I do multi-sequencing with the Motif, Sunsyn freaks out totally. With Cubase, everything is fine.Jazzpunk wrote:Most of us will most likely not have the chance to try out a Sunsyn if we actually find one to purchase, would you mind expanding on some of the Sunsyn's 'quirks'?
Other quirks... The tuning can be a bit 'alive' but with a decent warm-up time, this evens out. If you haven't calibrated your filters and envelopes in a while, voices can sound different from each other (I actually liked this) and even after calibration there is a little variation, especially with envelope releases. There is no portamento for RCOs. Noise levels can get a bit high, depending on your patch (high resonance and/or low osc levels). Deep PWM can distort some recording preamps(!).
That's all I can come up with at the moment. For me, the positive sides of the Sunsyn far outweigh the negatives. It just sounds so bloody amazing.
- CM
